Retch32 Posted March 7, 2014 Report Share Posted March 7, 2014 Ive got a 1999 4xv that ive owned for 11 years this year! Its just done 27,000 miles and has always used a bit of oil but back end of last year its was using a lot. Now spring is upon us going to have to get it sorted. Anybody know what goes wrong? Am thinking its more that just valve seals cheers all Link to comment Share on other sites More sharing options...
srad34 Posted March 7, 2014 Report Share Posted March 7, 2014 Yamaha = oil usage.......mine used loads! Link to comment Share on other sites More sharing options...
ronenige Posted March 7, 2014 Report Share Posted March 7, 2014 Quite a few do use a fair bit, you are allowed a litre per 1000 miles,check bores are round, re ring and valve seals but also check the guides as they have been known to wear,don't use fully synthetic in it either Link to comment Share on other sites More sharing options...
kja.busa Posted March 7, 2014 Report Share Posted March 7, 2014 Rings and stem seals. Link to comment Share on other sites More sharing options...
Alex_H Posted March 7, 2014 Report Share Posted March 7, 2014 Mine munches it, always has, 3 times as bad on a track day. Thats why they fitted an oil level sensor for you lol Link to comment Share on other sites More sharing options...
Beanerno1 Posted March 8, 2014 Report Share Posted March 8, 2014 Oil is so much cheaper than gaskets/rings/stems arf... Er yer mine uses a little oil too Link to comment Share on other sites More sharing options...
Evilchicken0 Posted March 8, 2014 Report Share Posted March 8, 2014 How is it using the oil ? Is it smoking out the pipe, or out the breather ? Check the plugs aren't oiled up Link to comment Share on other sites More sharing options...
smobytoe Posted March 8, 2014 Report Share Posted March 8, 2014 Years ago in pb olly crick rebuilt his 4xv. When he measured the wear it showed it was the valve stem seals that were allowing the oil to be burned. My 5jj uses about one litre every 3000 miles. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted March 8, 2014 Report Share Posted March 8, 2014 Really though all these things are leading to a top end rebuild. Hone the bores, renew the rings, clean the head and redo the valves. While your down there you cold get the head flowed raise compression a little and have the cams dialed in, you'll end up with a refreshed engine. A lot more money than using oil though. Link to comment Share on other sites More sharing options...
Retch32 Posted March 8, 2014 Author Report Share Posted March 8, 2014 Cheers for all the replies! As to how much oil it's using, am topping up before I go anywhere and pottering about it's not bad but hammering it well within 100 mile the light will come on, god knows what it would be like on a track day! Like the sound of evilchicken0 reply, got a budget of £1000ish Link to comment Share on other sites More sharing options...
smobytoe Posted March 8, 2014 Report Share Posted March 8, 2014 Dude you should get a refresh for a grand easy!! That means you can get the gearbox checked while the engine is out too! Link to comment Share on other sites More sharing options...
2Smoke Posted March 8, 2014 Report Share Posted March 8, 2014 Mine was using a litre per trackday usually. Nothing to worry about Link to comment Share on other sites More sharing options...
ronenige Posted March 8, 2014 Report Share Posted March 8, 2014 alternatively , find a dealer with a 5pw and see what sort of deal you can get with your bike and a grand Link to comment Share on other sites More sharing options...
Evilchicken0 Posted March 8, 2014 Report Share Posted March 8, 2014 Try Marcaztls off here he has a passing interest in them. Link to comment Share on other sites More sharing options...
MonkeyJim Posted March 10, 2014 Report Share Posted March 10, 2014 Cheers for all the replies! As to how much oil it's using, am topping up before I go anywhere and pottering about it's not bad but hammering it well within 100 mile the light will come on, god knows what it would be like on a track day! Like the sound of evilchicken0 reply, got a budget of £1000ish that sort of consumption does sound excessive my original 4xv engine used to use quite a bit, probably a litre every thousand miles or so, which never used to bother me. the 2nd engine used considerably less, and only ever needed the odd top up every few thousand miles. A couple of mates with 4xv/5jj engines use somewhere in between those two examples. Link to comment Share on other sites More sharing options...
exuprob Posted March 11, 2014 Report Share Posted March 11, 2014 Mine used a litre going from Oxfordshire to Alicante so I must have a frugal one!!! Link to comment Share on other sites More sharing options...
Retch32 Posted March 12, 2014 Author Report Share Posted March 12, 2014 We'll think it engine out and find somebody to rebuild top end, try and chase a few more horsepower while it's out!! Link to comment Share on other sites More sharing options...
