3tj6 Posted February 9, 2014 Report Share Posted February 9, 2014 Hi all im in the process of building a fzr 3tj hybrid for trackdays ,only I have a problem with an exhaust stud previously it has been snapped off breaking part of the casting away, somebodys bodgged it up by drilling into the head and tapping it out but in doing that have gone into cylinder heads oilway ,I have tried to fix it with chemical metal,and replacing the stud this worked ok until engine got up to temperature .then oil started dripping from the stud again .anybody any other ideas how to fix it other than having it welded up and retapping it ,thanks in advance jon Link to comment Share on other sites More sharing options...
Beanerno1 Posted February 9, 2014 Report Share Posted February 9, 2014 If you can get to the inside oil way and block it somehow you could use some easyweld, then just stick the stud back and it'll leave a nice theaded hole, Link to comment Share on other sites More sharing options...
Superdunc Posted February 9, 2014 Report Share Posted February 9, 2014 Pile of copper washers between the head and exhaust flange.A bodge, but it might just work. Link to comment Share on other sites More sharing options...
3tj6 Posted February 9, 2014 Author Report Share Posted February 9, 2014 Thanks for the info,thanks martin for the info on a local welder,but bendy off the forum says he will be able to sort it out,had work done by him before and has always been 100% cheers jon Link to comment Share on other sites More sharing options...
3tj6 Posted February 17, 2014 Author Report Share Posted February 17, 2014 Bendy has welded it and all good now,knows his stuff 100% Link to comment Share on other sites More sharing options...
