uglymark Posted February 1, 2014 Report Share Posted February 1, 2014 What's the best way of cleaning the Finns on a radiator . Any type of cleaner or just normal degreaser and elbow grease with a tooth brush and a pick to get the crap out . Link to comment Share on other sites More sharing options...
Discosef Posted February 1, 2014 Report Share Posted February 1, 2014 I usually use a weakish pressure washer. Get the crap out easily enough. Link to comment Share on other sites More sharing options...
tonk Posted February 2, 2014 Report Share Posted February 2, 2014 I asked the same question in January, the advice was to remove the radiator and use an ultrasonic cleaner but I didn't want to take it off. Instead I removed the fan and housing from behind the rad (air-cooled inline four), squirted in that pink muc-off from the front and used a garden hose from behind. I repeated that 3 times and then it was pretty squeaky clean. I used a few cocktail sticks to get the remaining giant beasties out and straighten up a couple of flat fins and rinsed again. A brush just gets snagged on the fins. Mine was properly crudded though, most of it was manure and salt (mmm, tasty) but my commute is via a lot of back roads past farms. Link to comment Share on other sites More sharing options...
svingel Posted February 8, 2014 Report Share Posted February 8, 2014 Same-ish...flatened a piece of stainless welding wire in one end, and bent the other end into a kind of handle. I suppose the ultra sonic would remove the slight corrosion too? Link to comment Share on other sites More sharing options...
