Toneale Posted December 6, 2013 Report Share Posted December 6, 2013 I am hoping the collective intelligence of the PB massive could point me in the right direction, I need to tidy the wiring on my blade, (i.e get rid of the wires that have been soldered several times and the copious amounts of insulting tape) and need supplies, basically lots of wire, shrink wrap and I would also like to upgrade the connectors. Q1. Any particular suppliers for the wire and shrink wrap? Q2. Some recommendations for decent waterproof connectors please? And lastly can someone recommend me a decent soldering iron and solder? Ladies, gentlemen and Greengoatcatcher the floor is yours. Ta Link to comment Share on other sites More sharing options...
Evilchicken0 Posted December 6, 2013 Report Share Posted December 6, 2013 Vehicle Wiring Products supply most things. I use a crimping ratchet tool rather than soldering. Its easier to just replace the loom and usually doesn't cost much more either Link to comment Share on other sites More sharing options...
VanWinkle Posted December 6, 2013 Report Share Posted December 6, 2013 maplins do spools of wire, I use a wee gas soldering iron I got from aldi, it even has an attachment for shrinking your wrap..which you can also buy from Maplins... full circle there eh.. Link to comment Share on other sites More sharing options...
Cibbersicks Posted December 7, 2013 Report Share Posted December 7, 2013 For sheathing (fnaar) use mesh, looks far more professional - I think RS Components do it but at present their site is down for maintenance so can't look. For connectors get hold of these:http://www.wurth.co.uk/data/productdocuments/030085.pdf They come in a large case of varying sizes with all the pins and seals you'll ever need. I've used them all over my CBR and found them pretty reliable. With connectors it depends on your budget really. You can really go to town, but for a decent quality job for not a lot of money you can't go wrong with the Wurth connectors - You can also get rubber boots for them so no need for copious amounts of tape to terminate them, but I'm not at my laptop right now so I don't have the bookmark, I'll post it in the morning. Been meaning to get some of the boots myself, well reminded. If you want to have something a little more "race blingy" look up Binder connectors - fairly priced too, but not sure what wires you're dealing with so may not be suitable. Link to comment Share on other sites More sharing options...
millerich Posted December 7, 2013 Report Share Posted December 7, 2013 If it helps, vehicle wiring products sell those connectors. They might not be badged as Wurth, but they do have them. I've used them for providing a 12v feed to the sat nav on the bike. Link to comment Share on other sites More sharing options...
willbloke Posted December 7, 2013 Report Share Posted December 7, 2013 Never used them myself , but someone here recommended these people. http://kojaycat.co.uk/ Link to comment Share on other sites More sharing options...
Cibbersicks Posted December 7, 2013 Report Share Posted December 7, 2013 Here's the link for the rubber boots for the connectors: http://www.simtekuk.co.uk/index.php/cable_accessories/connector_boots/?k=:14:143045: Link to comment Share on other sites More sharing options...
trevorb Posted December 7, 2013 Report Share Posted December 7, 2013 Those connectors are generically known as "superseal" connectors Link to comment Share on other sites More sharing options...
Toneale Posted December 8, 2013 Author Report Share Posted December 8, 2013 Thanks for the sage advice chaps. Anyone have an opinion on a decent soldering iron and solder? Link to comment Share on other sites More sharing options...
willbloke Posted December 8, 2013 Report Share Posted December 8, 2013 I wouldn't solder anything if I could avoid it , solder is brittle , the best bet is crimping , cable stays flexible . Link to comment Share on other sites More sharing options...
Cibbersicks Posted December 8, 2013 Report Share Posted December 8, 2013 Not everything gives the luxury of crimping unfortunately when it comes to really thin gauge work. Soldering done properly with adhesive heatshrink to support the joint should be fine. Link to comment Share on other sites More sharing options...
lorenzo Posted December 8, 2013 Report Share Posted December 8, 2013 Thanks for the sage advice chaps. Anyone have an opinion on a decent soldering iron and solder? I went for the cheapest iron that maplins had that was heat adjustable but a decent power. That way you can get a good bit of temperature to do thicker cable but don't melt the fuck out of the finer stuff. Link to comment Share on other sites More sharing options...
Damnthistinleg Posted December 8, 2013 Report Share Posted December 8, 2013 I thought this thread was going to be about a Chinese bloke accidentally touching a live wire. Disappointed. Link to comment Share on other sites More sharing options...
krazyk Posted December 26, 2013 Report Share Posted December 26, 2013 I've been using the Würth type on mine. A bit fiddly in tight places and you need a good crimper but excelent connecters. Link to comment Share on other sites More sharing options...
vfiend Posted December 29, 2013 Report Share Posted December 29, 2013 Another vote for vehicle wiring products here. Link to comment Share on other sites More sharing options...
