drunkn munky Posted December 4, 2013 Report Share Posted December 4, 2013 Whats the best procedure for cleaning some pretty grotty and tarnished pipework? Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted December 4, 2013 Report Share Posted December 4, 2013 vapor blast. then either leave it as is, or scotchbrite it to get the brushed look some come with. Link to comment Share on other sites More sharing options...
drunkn munky Posted December 4, 2013 Author Report Share Posted December 4, 2013 So no point attempting at home with anything then? Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted December 4, 2013 Report Share Posted December 4, 2013 if they look like they need cleaning, then its folly to think you can do it by hand. if they look ok-ish, it'd still be a pita to get them looking mint. Link to comment Share on other sites More sharing options...
dansp1 Posted December 4, 2013 Report Share Posted December 4, 2013 I have had great success with mild acid on stainless pipes, worth a try? Link to comment Share on other sites More sharing options...
drunkn munky Posted December 4, 2013 Author Report Share Posted December 4, 2013 No thats fine its the advice I was after, I'll save my elbow grease for something else Link to comment Share on other sites More sharing options...
Damnthistinleg Posted December 4, 2013 Report Share Posted December 4, 2013 I've had good results with an orbital sander followed by one of those foam pads with a very fine grit embedded in it but by Christ, it made my arms ache. This was on stainless pipes, however. On the plus side, I can now wank myself into oblivion at the drop of a hat. Link to comment Share on other sites More sharing options...
jollygiant Posted December 4, 2013 Report Share Posted December 4, 2013 If it Ti has it just 'blued'? On my old stainless pipes I found a polishing kit you fitted to your drill with 3 different grade mops and soap was brilliant and only cost about £25. I'm presuming this would work just as well on Ti? Link to comment Share on other sites More sharing options...
