exuprob Posted December 4, 2013 Report Share Posted December 4, 2013 While the R1 is off the road for the Winter, I was wondering if you can set carb balance while the carbs are off the bike or do they have to be fitted, and the bike running to set them up properly? Link to comment Share on other sites More sharing options...
BudgetBoy Posted December 4, 2013 Report Share Posted December 4, 2013 You can bench balance them which will get them near but you might still need a carbtune to set them 100%. You can use a bit of say Mig wire and set the throttle plates so they are all the same. Link to comment Share on other sites More sharing options...
marcaztls Posted December 4, 2013 Report Share Posted December 4, 2013 I've done it with a drill bit before and the results have been very close, but you'll never get them as perfect as you can on the bike due to different cylinder vacuums. It's a good starting point though. Link to comment Share on other sites More sharing options...
lorenzo Posted December 4, 2013 Report Share Posted December 4, 2013 Likewise, done it with a small drill bit in the past and it'll get your bike started, but it's never going to be spot on. Link to comment Share on other sites More sharing options...
Kayla Posted December 5, 2013 Report Share Posted December 5, 2013 Ah, the council balance Link to comment Share on other sites More sharing options...
ronenige Posted December 5, 2013 Report Share Posted December 5, 2013 Usually there is a series of very small holes ( progression jets) very close to where the butterfly sits, if you look at the proximity of the butterfly to these holes you can get very close But it will still be better with the engine running Link to comment Share on other sites More sharing options...
exuprob Posted December 6, 2013 Author Report Share Posted December 6, 2013 Ah Ok, so it'll be in the ball park but not dead on then. That's close enough, cheers. Link to comment Share on other sites More sharing options...
