ssray Posted November 30, 2013 Report Share Posted November 30, 2013 Morning, My an400x burgerman has a not very nice yellow spark, I have checked the usual and also its a poor starter the new plug while cold , no start plug was wet, the carb comes off next week I was thing if i can get a single correct ohm plug coil is there any reason why it will not work? I haven`t checked on the ohm`s of mine yet Cheers Ray Link to comment Share on other sites More sharing options...
kaighn80 Posted November 30, 2013 Report Share Posted November 30, 2013 So long as the coil is the same as the one your replacing it with (resistance wise) then it will work, after all the coil doesn't know if its a stick or not, they work in exactly the same way just don't have a lead to go wrong, it's something I've been planning for my vfr750 Link to comment Share on other sites More sharing options...
ssray Posted November 30, 2013 Author Report Share Posted November 30, 2013 Thanks, need the find out what ohm one I have now Link to comment Share on other sites More sharing options...
ssray Posted November 30, 2013 Author Report Share Posted November 30, 2013 I need 3 to 5 ohm`s, it looks like stick coils are around 0.7 to 1.6 ohms, would to low hurt the cdi etc? Link to comment Share on other sites More sharing options...
ssray Posted November 30, 2013 Author Report Share Posted November 30, 2013 if i can only get say a 1.5 ohm coil could i add a 2ohm resistor to it? Link to comment Share on other sites More sharing options...
kaighn80 Posted November 30, 2013 Report Share Posted November 30, 2013 Ill throw a guess out, I'm going to say no, the reason being the amount of current thrown by a coil is likely to not be happy with a resister, there must be something out there with the right resistance, think the guy you may need to ask is millemille Link to comment Share on other sites More sharing options...
ssray Posted November 30, 2013 Author Report Share Posted November 30, 2013 The resister would go on the posi side before the coil also looking at maplin, if i could not get one 2 ohm resistor i could solder two 4 ohm in parallel or two 1 ohm in series Ta Ray Link to comment Share on other sites More sharing options...
ssray Posted December 1, 2013 Author Report Share Posted December 1, 2013 Cool ta, have got a ducati one from evilbay for £4, will give it a go Thanks Ray Link to comment Share on other sites More sharing options...
Superdunc Posted December 1, 2013 Report Share Posted December 1, 2013 Just a heads up on Ducati stick coils. If it's dirty or has any corrosion, it's off the front pot, and probably knackered. Link to comment Share on other sites More sharing options...
ssray Posted December 1, 2013 Author Report Share Posted December 1, 2013 supposed to be brand new and even unused Link to comment Share on other sites More sharing options...
Superdunc Posted December 2, 2013 Report Share Posted December 2, 2013 supposed to be brand new and even unusedBargain. I paid £120 from Ducati..... Link to comment Share on other sites More sharing options...
ssray Posted December 5, 2013 Author Report Share Posted December 5, 2013 Struggling to find a 2-3 ohm resistor, would 2 of these glued/taped in line do? http://www.maplin.co.uk/search?text=m1r5&x=0&y=0 this would be on the posi side Ta Ray Link to comment Share on other sites More sharing options...
kaighn80 Posted December 5, 2013 Report Share Posted December 5, 2013 If your having issues finding the right values try rapid or rs components, rapid are based in Colchester and carry a lot of stock Link to comment Share on other sites More sharing options...
kaighn80 Posted December 5, 2013 Report Share Posted December 5, 2013 This may do but check first http://m.rapidonline.com/ProductSearch/ProductDetails?ProductCode=51-8963&ModuleCode=528646 Link to comment Share on other sites More sharing options...
