srad34 Posted November 23, 2013 Report Share Posted November 23, 2013 Hi all, I have a used gear indicator, no plug in connector and want to fit to my CBR900RRX, I have downloaded the Datatool pdf showing the wiring, but all of the wire colours that it states for the 96-99 Fireblade's don't match what's on the bike! When I run the bike, it shows 1 when in first then flicks up to 5 and 6 as I move??? Could this mean the tacho and speedo feed are the wrong way round? The 97-98 blades still had mechanical cable speedo as far as I know so why does datatool say they are the same? (The RRW/RRX had the digital speedo and tacho y'see If anyone had fitted one or can advise, I would be grateful. Cheers Link to comment Share on other sites More sharing options...
Evilchicken0 Posted November 24, 2013 Report Share Posted November 24, 2013 I had one of those. Never fitted it though - not much help huh ? Why not give the a bell in the morning. Link to comment Share on other sites More sharing options...
srad34 Posted November 24, 2013 Author Report Share Posted November 24, 2013 Going to try the 'learning sequence' thing on the install guide again, failing that remove it with fire...... Link to comment Share on other sites More sharing options...
