phildawson8270 Posted November 15, 2013 Report Share Posted November 15, 2013 I am hoping for a bit of assistance, either to tell me I'm stupid, or that I am good to go. I know that drilling frames is a bit of a taboo, and I am aware of the risks. However, I am unsure on the severity of these risks, and the possibility of them occuring. This information is for my Formula400 build. Whilst the nose fairing is hung off my bracket turned up by Kayla, and the lower belly pan brackets are easy enough to sort out as I can use existing mounts on the engine cradle. The issue is with the side fairings. The mounting holes in the fairing line up directly to my frame. I am planning on drilling and putting an M8 rivnut in the frame, which will be around a 10mm hole, whilst I believe that once the rivnut is fitted and there is a bolt in there, that will reduce the stress from the drilled hole, however, how concerned should I be with stress fractures appearing from the location of drilling? The distance between the fairing and the frame is very close, pretty much being able to bolt straight in to the frame with maybe a 12mm to 15mm spacer minimum, and with non-folding pegs, I don't think the frame would hit the floor in most crashes. The pencil in the following photo is pointing to the area I intend to drill and rivnut. It is, as you can see on a flat, however, it is right before a bend in the frame. For information: Suzuki already have 4 rivnuts in the frame near the head stock, 2 for original fairing mounts, and 2 for front subframe. Thanks guys Link to comment Share on other sites More sharing options...
Gmanb1h Posted November 15, 2013 Report Share Posted November 15, 2013 I would get external nut welded onto frame so no spacer would be required ;-) Like factory steering damper mounts of days gone by. http://i184.photobucket.com/albums/x218/cb900/parts/damperMount.jpg Link to comment Share on other sites More sharing options...
kaighn80 Posted November 15, 2013 Report Share Posted November 15, 2013 Would the heat being localised mean that the frame then needs heat treating incase of fatigue? Link to comment Share on other sites More sharing options...
lorenzo Posted November 15, 2013 Report Share Posted November 15, 2013 I drilled a little 4 or 5mm hole in the side of the frame on the srad and I didn't die. Link to comment Share on other sites More sharing options...
spacemonkey Posted November 15, 2013 Report Share Posted November 15, 2013 Surely just be carful not to weaken it in a highly stressed place and make sure you deburr and radius off the edges? Link to comment Share on other sites More sharing options...
kaighn80 Posted November 15, 2013 Report Share Posted November 15, 2013 Thing is to an eager amateur how would we know where is good and where is less good, it's not like frames come with center punched points where it's safe to drill Link to comment Share on other sites More sharing options...
Superdunc Posted November 15, 2013 Report Share Posted November 15, 2013 Rivnut there will be fine, take your time drilling the hole, and make sure you deburr it nicely. Link to comment Share on other sites More sharing options...
phildawson8270 Posted November 15, 2013 Author Report Share Posted November 15, 2013 Thanks, I've gone for an M6 rivnut and using shouldered bolt through the fairing so that I am drilling the smallest hole necessary. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted November 16, 2013 Report Share Posted November 16, 2013 Measure the rivinut and match the drill bit to it. I'd use a splined one and a bit of JB weld to hold it. Link to comment Share on other sites More sharing options...
Leighio Posted November 16, 2013 Report Share Posted November 16, 2013 Also to keep the temperature down use some form of oil as a coolant, I know with stainless and other non ferrous material you should not bit if your worried about heat this should help. Link to comment Share on other sites More sharing options...
jollygiant Posted November 16, 2013 Report Share Posted November 16, 2013 What could possibly go wrong…….. Try it and if you die you know it didn't work. Link to comment Share on other sites More sharing options...
Simbo Posted November 16, 2013 Report Share Posted November 16, 2013 Fuck it. How bad can it be Link to comment Share on other sites More sharing options...
