Spyder75 Posted November 10, 2013 Report Share Posted November 10, 2013 Raging... Sunny Sunday afternoon, wife out on a ladies lunch thing and kids with grandparents. Go to fire the bike up and it's not working. It's a cbr600 fx It's been sitting for a few weeks Battery is turning it over. Took a few goes to get it going but it sounded rough (not running on all cylinders?) Left it running for a minute with the choke on but revs were slowly dropping. It stalled when I gently blipped the throttle. Have left it sitting now in case I've flooded it? Help please? Any thoughts or suggestions? Please bear in mind I probably have less mechanical knowledge than Jordan (Katie, not Eddie) Having a coffee while in the huff Link to comment Share on other sites More sharing options...
BudgetBoy Posted November 10, 2013 Report Share Posted November 10, 2013 Crap in pilot jets or water/condensation in float bowls. Also if it struggled to start id charge the battery up just to be sure Link to comment Share on other sites More sharing options...
bignige Posted November 10, 2013 Report Share Posted November 10, 2013 Try it again. Battery on charge overnight. Sunny weather tomorrow, take the day off work. :-) Link to comment Share on other sites More sharing options...
VanWinkle Posted November 10, 2013 Report Share Posted November 10, 2013 stick some redX in it..clear some of the crap out the fuel lines.. Link to comment Share on other sites More sharing options...
Spyder75 Posted November 10, 2013 Author Report Share Posted November 10, 2013 Has plenty fuel in it Don't have a battery charger (as I've no electric points in the shed used for storing it) but I'll get one and some red x Cheers Link to comment Share on other sites More sharing options...
Mahatma Posted November 10, 2013 Report Share Posted November 10, 2013 Probably washed it and stored it,and got water gremlins in it.If you get it started,just take it for a gentle spin,and the water will get out.Empty the carbs,and use startergas to get it going. Link to comment Share on other sites More sharing options...
Spyder75 Posted November 10, 2013 Author Report Share Posted November 10, 2013 Empty the carbs? Ummmmm.... May I refer sir to my comment about my mechanical knowledge? Link to comment Share on other sites More sharing options...
Mahatma Posted November 10, 2013 Report Share Posted November 10, 2013 ok,get a car and tow-start it then Link to comment Share on other sites More sharing options...
Spyder75 Posted November 11, 2013 Author Report Share Posted November 11, 2013 Optimate on the way courtesy of amazon. Will charge battery first then try changing plugs Link to comment Share on other sites More sharing options...
Simbo Posted November 12, 2013 Report Share Posted November 12, 2013 Choked up while on choke. Now flooded. Leave to dry plugs and crank over when charged up. No choke and throttle wide open. This helps to dry out any fuel left. Link to comment Share on other sites More sharing options...
Spyder75 Posted November 17, 2013 Author Report Share Posted November 17, 2013 Took a few days to fully charge the battery as it was in a bad way. Seems to be holding a charge now. It's turning over but doesn't seem to want to start. New plugs next? Link to comment Share on other sites More sharing options...
thefatman Posted November 17, 2013 Report Share Posted November 17, 2013 If it took a few days to charge up then the battery is probably past its best. I'd try jumping it from a car, do it in short bursts so you don't overheat the starter motor though. Try it without the choke on first of all to clear it out. Link to comment Share on other sites More sharing options...
Spyder75 Posted November 17, 2013 Author Report Share Posted November 17, 2013 Charged it in the bike for 24 hours but must have been too far gone as it didn't charge. Took it out the bike and charged it for 24 hours and its fully charged now. Blinky green light on the optimate is telling me its holding the charge too, I think Might swap it out anyway just to be sure... Link to comment Share on other sites More sharing options...
ssray Posted November 17, 2013 Report Share Posted November 17, 2013 have you tried easy start? it will at least start on one or two, easiest way to tell? which down pipe burns your hand(if poss use somebody elses hand) then get back to us Ray Link to comment Share on other sites More sharing options...
kwakbiker Posted November 17, 2013 Report Share Posted November 17, 2013 It might be holding charge but the cells in the battery may well be fooked and just discharging when pressing the starter, new set of plugs and battery will no doubt see it right Link to comment Share on other sites More sharing options...
Spyder75 Posted November 17, 2013 Author Report Share Posted November 17, 2013 have you tried easy start? it will at least start on one or two, easiest way to tell? which down pipe burns your hand(if poss use somebody elses hand) then get back to us Ray Not tried that... Will give it a go while I'm waiting on new battery and plugs being delivered Link to comment Share on other sites More sharing options...
