Alex_H Posted September 27, 2013 Report Share Posted September 27, 2013 I've just stuck a 5eb head on a 5sl bottom end and put it in a 5eb frame. Now the mounts at the front line up apart from one that isn't on the 5sl bottom. The lower rear also goes ok, it's just the rear upper that I've got trouble with Question is what would you do with it, cut frame and add brackets or try it as is? I'm not sure if cutting it all to add some dinky brackets would make a lot of difference to strength or rigidity? Link to comment Share on other sites More sharing options...
Evilchicken0 Posted September 28, 2013 Report Share Posted September 28, 2013 Not sure I'd want to ride it like that. The shafts look to close to fit a bracket and get any strength between them. Link to comment Share on other sites More sharing options...
Rick448 Posted September 28, 2013 Report Share Posted September 28, 2013 I'd assume if they weren't needed they wouldn't be there. I'd think it would put more stress onto the other mounts. Link to comment Share on other sites More sharing options...
Jenny Pryde Posted September 28, 2013 Report Share Posted September 28, 2013 Cabbie will know. Link to comment Share on other sites More sharing options...
Guest Posted September 28, 2013 Report Share Posted September 28, 2013 You'll easily get a cable tie through there Link to comment Share on other sites More sharing options...
Alex_H Posted September 29, 2013 Author Report Share Posted September 29, 2013 So I've read and considered all of your posts gentlemen, and I think what you're trying to tell me is "ebay the fucker" Link to comment Share on other sites More sharing options...
srad34 Posted September 29, 2013 Report Share Posted September 29, 2013 You'll easily get a cable tie through there Bodgery at PBF's finest! - PS Make sure its not one of them cheap ones! Link to comment Share on other sites More sharing options...
ZZR monkey Posted September 29, 2013 Report Share Posted September 29, 2013 Oval the holes - open up the holes on the other mounts a little too and you should be able to get a decent bolt through all the mounts then. Link to comment Share on other sites More sharing options...
ZZR monkey Posted September 29, 2013 Report Share Posted September 29, 2013 Oval the holes that almost line up, looks to be enough metal to not loose too much strength. Open the holes on the other mounts too and you'll probably get just enough movement to get bolts through all the mounts. Job jobbed. Link to comment Share on other sites More sharing options...
Mrdrink Posted September 29, 2013 Report Share Posted September 29, 2013 What happens when you release the front mounts and cock the engine back? do they line up then? Ive heard the front mounts need attention on this but not the rear. Another thing, the 5EB kit manual is quite specific about how to fit the engine to make sure proper handling is retained which suggests that this could cause handling issues if not appropriately dealt with. Link to comment Share on other sites More sharing options...
Alex_H Posted October 1, 2013 Author Report Share Posted October 1, 2013 Best I replied, been on the car due to mot failure, poxy thing. Anyway, when you chock the motor back with the front mounts released, the hole gets nearer but not near enough. It also starts to get far too close to the swingarm. I'm not too keen on adjusting the front mounts as they all line up perfectly, and the airbox fits where it should, airtubes etc all go together perfectly. Also i dont think ovaling the holes will do a lot for me either, the rhs has a threaded collar which is quite thin. Awkward one this really. Link to comment Share on other sites More sharing options...
Chris Posted October 1, 2013 Report Share Posted October 1, 2013 Over size the hole (massive) plug the hole and re-centre the hole (on the plug) to fit with the one behind. Link to comment Share on other sites More sharing options...
Chris Posted October 1, 2013 Report Share Posted October 1, 2013 Plug needs to be top hat type. Link to comment Share on other sites More sharing options...
gsxr renegade Posted October 1, 2013 Report Share Posted October 1, 2013 Over size the hole (massive) plug the hole..... Hehehe Link to comment Share on other sites More sharing options...
Alex_H Posted October 2, 2013 Author Report Share Posted October 2, 2013 Plug needs to be top hat type. This is actually the way forward with this, and as I can't see me ever doing it I have actually chucked it on ebay. If anyones interested, gis a pm and I'm sure a pb'er wont get a cheaper r6 to play with Link to comment Share on other sites More sharing options...
