thefatman Posted September 24, 2013 Report Share Posted September 24, 2013 Any tips on this "Any pointers on how to adjust the clutch on my bike. Freshly fluid, but I cant get quite enough purchase on the levers (have played with the distance adjuster). Neutral is only possible with the engine off." Link to comment Share on other sites More sharing options...
chocyboy Posted September 24, 2013 Report Share Posted September 24, 2013 There is a how to over on rsvr.net on this. There is a injector thingiemabob that you change for one off a later model and it sorts the neutral issue out. Can't help more ATM as I'm out dogging. Link to comment Share on other sites More sharing options...
Gregorious77 Posted September 25, 2013 Report Share Posted September 25, 2013 Indeed. Search for clutch jet. The oil feed tot he clutch plates caused drag on the clutch making finding neutral difficult on some bikes. The oilway has a jet the same as an idle jet in a carb to reduce the flow. In the earlier bikes the jet is too ig letting in too much oil and causing the drag. A different sized jet can be purchased and swapped over to cure the problem. later bikes came with this fitted. Link to comment Share on other sites More sharing options...
thefatman Posted September 25, 2013 Author Report Share Posted September 25, 2013 Thanks, i'll pass it on Link to comment Share on other sites More sharing options...
