MonkeyJim Posted September 24, 2013 Report Share Posted September 24, 2013 after a set of crowfoot spanners aka crows feet for a couple of jobs on the bike reason for the question is it looks like they come in two sorts, either open ended, like this or with a small lip at front, like this I'm guessing but the former is easier for access, the latter will keep a better grip once it's on / in place? anyone got any recommendations, pros/cons for either type? looking at getting a set for a 3/8" drive, as I need at least a 14mm, 17mm and 22mm and it'd be handy to have the sizes in between as well. Link to comment Share on other sites More sharing options...
Doug_R1 Posted September 24, 2013 Report Share Posted September 24, 2013 Isn't the second one for flare nuts? Link to comment Share on other sites More sharing options...
chancho196 Posted September 25, 2013 Report Share Posted September 25, 2013 The second type is the best bet for tight nuts and bolts, but can't always get into some spots. The first type will "open up" easily, and round off bolts if too tight. You can buy them so cheaply nowadays that I'd suggest getting both types. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted September 25, 2013 Report Share Posted September 25, 2013 I've got some of these, but never used them. Link to comment Share on other sites More sharing options...
