Mahatma Posted August 27, 2013 Report Share Posted August 27, 2013 Anyone know if an 2001(and newer) gastank from a VTR 1000 firestorm can be bolted straight on a 2000 model? Link to comment Share on other sites More sharing options...
lorenzo Posted August 27, 2013 Report Share Posted August 27, 2013 Isn't this when they changed from carbs to injection? If so, I'd imagine the pump will be fairly different. I'd haver a look for a parts fiche and compare the part numbers for the gasket on the fuel pump, see if you can swap your old pump into the newer tank. Link to comment Share on other sites More sharing options...
Turok Posted August 27, 2013 Report Share Posted August 27, 2013 The Firestorm never had injection. The best place to ask is VTR1000.org. I think that it's a straight swap. You can also fit a VFR tank onto them, but it takes a bit of modding http://www.superhawkforum.com/forums/modifications-cosmetic-34/vtr-vfr-tank-pro-modification-30030/ Link to comment Share on other sites More sharing options...
Mahatma Posted August 27, 2013 Author Report Share Posted August 27, 2013 Thanks for quick answers.Will check it out if a straight swap to get bigger fueltank.Will stop more often for fuel if not;) Will check that website Turok:) Link to comment Share on other sites More sharing options...
lorenzo Posted August 27, 2013 Report Share Posted August 27, 2013 The Firestorm never had injection. What the hell was I thinking of then?! Link to comment Share on other sites More sharing options...
Turok Posted August 27, 2013 Report Share Posted August 27, 2013 What the hell was I thinking of then?! Fireblades? They went injection in 2001 IIRC. Link to comment Share on other sites More sharing options...
Mahatma Posted August 27, 2013 Author Report Share Posted August 27, 2013 Fireblades? They went injection in 2001 IIRC. Not to nitpick,but they went FI in 2000.Let the bashing begin Link to comment Share on other sites More sharing options...
Turok Posted August 27, 2013 Report Share Posted August 27, 2013 Fireblades? They went injection in 2001 IIRC. Not to nitpick,but they went FI in 2000.Let the bashing begin I clearly didn't recall correctly... Link to comment Share on other sites More sharing options...
nigel.ted Posted August 28, 2013 Report Share Posted August 28, 2013 What the hell was I thinking of then?! red zx7r's they had Fi.................................. waits Link to comment Share on other sites More sharing options...
