SAB Posted August 27, 2013 Report Share Posted August 27, 2013 Will running narrow band brake calipers with wide band (stock) width rotors cause any major issues? I realize that the narrow band pads won't sweep the entire surface area of the wide band rotors, but will the rotors eventually develop a troublesome groove? Thanks in advance. Link to comment Share on other sites More sharing options...
Superdunc Posted August 27, 2013 Report Share Posted August 27, 2013 No it won't cause an issue. Eventually it will wear a groove, but that will only be an issue if you go back too standard calipers and pads. Link to comment Share on other sites More sharing options...
SAB Posted August 27, 2013 Author Report Share Posted August 27, 2013 Seth: The way you change your bikes they wouldn't get chance to wear a groove :-) In all seriousness it's difficult to say without seeing where the pad face is on the disc ( if that makes sense) Pots and kettles and all that! I think it will work. Going to give it a go. No it won't cause an issue. Eventually it will wear a groove, but that will only be an issue if you go back too standard calipers and pads. Thank you sir. PFM's are now en route. Link to comment Share on other sites More sharing options...
