originalracingsnake Posted August 19, 2013 Report Share Posted August 19, 2013 Typically I am off to Germany on the bike Friday... Bike runs perfectly over 3k, but idling to trickling along is a pain as the bike feels like it is dropping a cylinder, worse when cold. Bike has a DJPC3, and I have changed maps to base and tried several others so I do not,think it is a mapping issue. TPS? Any advice gratefully received. Link to comment Share on other sites More sharing options...
Stephenrc45 Posted August 19, 2013 Report Share Posted August 19, 2013 Pop a set of plugs in it. We get this quite a bit for some reason with the Suzuki's on the dyno. Link to comment Share on other sites More sharing options...
MonkeyJim Posted August 20, 2013 Report Share Posted August 20, 2013 wind the tick-over up to 3k. Job's a good 'un! Link to comment Share on other sites More sharing options...
originalracingsnake Posted August 20, 2013 Author Report Share Posted August 20, 2013 Plugs, briliant. Will swap them out and see what happens. Many thanks. Link to comment Share on other sites More sharing options...
MonkeyJim Posted August 20, 2013 Report Share Posted August 20, 2013 Sir, correct plugs are NGK CR9E and the plug gap is 0.7-0.8mm HTH Link to comment Share on other sites More sharing options...
trackdaybob Posted August 20, 2013 Report Share Posted August 20, 2013 wind the tick-over up to 3k. Job's a good 'un! Exactly what I was gonna say Link to comment Share on other sites More sharing options...
bazdude Posted August 21, 2013 Report Share Posted August 21, 2013 Regarding TPS, I found some info for another issue I was having ( my K5 was struggling to pull past 10K rpm) that mentioned when calibrating the TPS, set it on right on the cusp of the lcd bar moving from center to upper. Gave it a try and it worked perfectly. Now it bangs into the limiter no problems...... Link to comment Share on other sites More sharing options...
laney Posted August 27, 2013 Report Share Posted August 27, 2013 My k6 is doing the same, ive tried new plugs, ive tried about 75 different tickover settings, fresh fuel, blah blah... Its going into my local stealers next weekend to get plugged into the matrix...!!!! Link to comment Share on other sites More sharing options...
originalracingsnake Posted September 1, 2013 Author Report Share Posted September 1, 2013 Well, I got back yesterday and after 1400 miles, it is still doing it. Worse than ever now, as tickover sees it dropping onto 3 and only picking up the latent cylinder when over 2.5k RPM. That made riding in traffic a total bastard with about 20kg of luggage strapped on the Renntec rack and pillion seat. I'm going to change plugs anyway, even though it made no difference on yours and was going to get the TB's balanced too. Is it only the stealer that can interface with the ECU? Link to comment Share on other sites More sharing options...
MonkeyJim Posted September 3, 2013 Report Share Posted September 3, 2013 you can buy a 'dealer mode switch' and do it yourself http://www.ebay.co.uk/itm/Dealer-mode-tool-Suzuki-GSXR-1000-K3-on-/251023356143?pt=UK_Motorcycle_Parts&hash=item3a722870ef I haven't got one, but I did buy a PAIR blanking kit from this very same seller, it only took a couple of days to arrive (from greece) and was spot on. if you haven't got the workshop manual (to decipher all the fault codes etc) then PM me with your details and I can send you a copy via a CD or pdf on email Link to comment Share on other sites More sharing options...
Jenny Pryde Posted September 3, 2013 Report Share Posted September 3, 2013 Blip the throttle! In t'olden days, our tachos didn't even start 'til 3000rpm and we had to carry WD40 everywhere, in case it rained and t'engine died.Kids today...tch. They don't know they're born... ;-) Link to comment Share on other sites More sharing options...
laney Posted September 9, 2013 Report Share Posted September 9, 2013 Reluctantly sent my k6 into the stealers this weekend,and a new set of plugs and tb`s now balanced its spot on..... It seems i have knackered the plugs i put in, as the tb`s were the main cause of the rough running..... Link to comment Share on other sites More sharing options...
