ssray Posted August 14, 2013 Report Share Posted August 14, 2013 Had to bump the bike yesterday morning, so I charged it last night on my optimate, green light this morning, when i got to the bike after 9hrs I checked and had 15amps from the battery, started bike and it went up(brand new electrex reg/rec fitted last week) stopped after 10miles to chat to a mate,then the solenoid just clicked then just started The optimate was on red(deep discharge) charging spare at the mo Ray Link to comment Share on other sites More sharing options...
Leighio Posted August 14, 2013 Report Share Posted August 14, 2013 It could be the generator not charging. Link to comment Share on other sites More sharing options...
banoffee Posted August 14, 2013 Report Share Posted August 14, 2013 what's the voltage across the battery terminals at... static, ignition off bike ticking over revs held at around 4k unplug the generator plug, is there continuity between any of the terminals? what bike? Link to comment Share on other sites More sharing options...
ssray Posted August 15, 2013 Author Report Share Posted August 15, 2013 Ntv650, broke the leads on my meter last night! have charged the old spare batt for today, will see how that one is Ta Ray Link to comment Share on other sites More sharing options...
ssray Posted August 15, 2013 Author Report Share Posted August 15, 2013 Bump start this morning, the optimate was showing green (on the spare battery) plugged in and click,click etc I got to the station about 12 miles turned off and I would not turn over I`m going to borrow a hammer and screwdriver from work and bash the starter motor before I try and start it(and buy some new leads) Ray Link to comment Share on other sites More sharing options...
lorenzo Posted August 15, 2013 Report Share Posted August 15, 2013 Your old reg/rec (You want to hope it was your old one!) has probably boiled your battery dry in at least 1 cell, at a guess. Link to comment Share on other sites More sharing options...
ssray Posted August 15, 2013 Author Report Share Posted August 15, 2013 but the battery I put on this morning was a diffrent one, and it was full green on the optithing Link to comment Share on other sites More sharing options...
Leighio Posted August 15, 2013 Report Share Posted August 15, 2013 The optimate charger should tell you if the battery is knackered. If you say a fully charged battery would not start the bike then it is a starter issue. If your able to start the bike but it only runs for a while with lights and a hour ride then it will not start after then it's a charging fault_. Link to comment Share on other sites More sharing options...
ssray Posted August 15, 2013 Author Report Share Posted August 15, 2013 I`m going to try the starter tomorrow Link to comment Share on other sites More sharing options...
kwakbiker Posted August 17, 2013 Report Share Posted August 17, 2013 Had this over on the versys forum, twas indeed a battery that had gone, their optimate was showing charged but the battery just couldn't hold a charge for long or take a quick charge when riding along Link to comment Share on other sites More sharing options...
Egg on Leggs Posted August 17, 2013 Report Share Posted August 17, 2013 Optimate will not tell you about all battery problems. I had an 18 month old Yuasa that looked perfect on the charger but would then loose its charge over 2 days. Link to comment Share on other sites More sharing options...
millerich Posted August 17, 2013 Report Share Posted August 17, 2013 As I understand it, an Optimate will show you that a battery is charged to its capacity, but if it has started to fail then its capacity may be a fraction of what it should be and will be too little to perform its job. I've had several batteries that would show a green light on an Optimate but wouldn't turn the bike over. Link to comment Share on other sites More sharing options...
ssray Posted August 17, 2013 Author Report Share Posted August 17, 2013 I removed the starter and attached it directly to the two batts(one at a time) and ....nothing, new(s/h) one ordered, the carbon brushes were over half worn and lots of carbon dust in there, the commutator was discolored but I did not test anyfing Cheers Ray Link to comment Share on other sites More sharing options...
ssray Posted August 19, 2013 Author Report Share Posted August 19, 2013 New(s/h) one fitted today, we have go- Thanks Ray Link to comment Share on other sites More sharing options...
