1127kat Posted August 12, 2013 Report Share Posted August 12, 2013 Hello, has anybody got the info I need for changing a big standard acid battery for a new slimline li/ion replacement. it's an 1100 motor so needs a decent kick start and its a road bike so needs power to run light etc... There has been a write up somewhere in the press because I've seen it … just can't remember where I've seen it. Link to comment Share on other sites More sharing options...
Kayla Posted August 12, 2013 Report Share Posted August 12, 2013 An 8 cell LiFePO4 (lithium iron phosphate) not lithium ion will do the job Link to comment Share on other sites More sharing options...
V6Jon Posted August 12, 2013 Report Share Posted August 12, 2013 This is something I have been considering for my SRAD, which again is a road bike with all the associated electrics, so can I chip in with another question please ? Once you have purchased the above 8 cell LiFePO4 battery do you need to balance the charge between the cells in any way ? I know with my RC batteries I need a balance charger, and whilst my bike will undoubtedly provide enought power to charge the new battery is it ulitmately going to wreck it ?? Thanks Jon Link to comment Share on other sites More sharing options...
Kayla Posted August 12, 2013 Report Share Posted August 12, 2013 I don't know. The batteries I've been using come charged and balanced. They do have a balance plug attached though Link to comment Share on other sites More sharing options...
tomekzxr Posted August 12, 2013 Report Share Posted August 12, 2013 I use 8 cells A123 bought on ebay from China. Just soldered them together and made a pack myself and it was ready to use. Overall cost was just as regular battery. No balancing or any other tricks. Works for a third year with no problems. Link to comment Share on other sites More sharing options...
boris Posted August 22, 2013 Report Share Posted August 22, 2013 http://www.motydesign.com/ I used the 6 cell oem version and started my r1 several times when I was testing something and only needed a ten minute balance charge after plus its safe to use with a bikes charging system Link to comment Share on other sites More sharing options...
