Dan Posted August 4, 2013 Report Share Posted August 4, 2013 Got a bit of a front end problem,when I try and change direction from left to right like coming off a roundabout,the bikes feels very heavy to turn as if it wants to carry on in a straight line Now I've had the head races checked they are ok, I have had new tyres fitted and the guy commented on how much weight he had to add to balance the wheel,so I'm thinking it could be a damaged front wheel? On looking at the wheel I can't see any damage,but I guess it could be knocked out of true by general road conditions and use? Any other ideas or recommendations of places to get it checked and repaired? Link to comment Share on other sites More sharing options...
phildawson8270 Posted August 4, 2013 Report Share Posted August 4, 2013 Tyre pressures? Link to comment Share on other sites More sharing options...
monty_zac Posted August 4, 2013 Report Share Posted August 4, 2013 Sell it. That will cure the problem. Link to comment Share on other sites More sharing options...
Rick448 Posted August 4, 2013 Report Share Posted August 4, 2013 It's unlikely that damage to the front wheel would show up this way if it is Ok the rest of the time. Was it Ok before you had new tyres fitted? What tyres do you have on? Some have a profile which aids turning more than others. What settings are you using suspension wise? Loads of variables here with ride height front and rear, preload, and rebound damping at the front in particular. And of course as mentioned above, tyre pressures. If you give some more info we may be able to help. I guess the model of GSXR would be useful too. Link to comment Share on other sites More sharing options...
stupid luke Posted August 4, 2013 Report Share Posted August 4, 2013 Steering damper wound up too tight? HTH Link to comment Share on other sites More sharing options...
Dan Posted August 4, 2013 Author Report Share Posted August 4, 2013 It was fine before the tyres which Are rosso2's were fitted,I haven't changed any suspension settings,I'm just thinking its the front wheel as the tyre fitter commented he had to put the most amount of weights on the wheel to balance it. 04 gsxr 750 Chubbster get your wallet out you can have it,be easier than changing bodywork again! Link to comment Share on other sites More sharing options...
Rick448 Posted August 4, 2013 Report Share Posted August 4, 2013 Ok . What pressures are you running and what tyres did you have before? I run Rosso's on one of my bikes with no problems. Link to comment Share on other sites More sharing options...
banoffee Posted August 4, 2013 Report Share Posted August 4, 2013 Give me a shout if you want it checked over Dan. Link to comment Share on other sites More sharing options...
overload Posted August 4, 2013 Report Share Posted August 4, 2013 Have you checked the tyre pressure? It sounds as if it needs more. If not, take the front wheel off and check to see if it's true. Also check to see if the fitter has wrongly fitted the wheel spacers and spindle. It can happen. Link to comment Share on other sites More sharing options...
Dom Posted August 7, 2013 Report Share Posted August 7, 2013 Are they the same tyres you had on before? If not then perhaps they just handle differently? When I changed brands I nearly crashed into the first roundabout I came to! I dropped the pressures a bit and they were much better once scrubbed in. Link to comment Share on other sites More sharing options...
harry-h1 Posted August 7, 2013 Report Share Posted August 7, 2013 Diffrent profile to youre last tyres? Link to comment Share on other sites More sharing options...
