Toseland's Eyebrows Posted July 15, 2013 Report Share Posted July 15, 2013 Hi all, I finally fixed the leaky gasket on my little Honda and attacked some of the corrosion on my exhaust with a wire brush, it came up ok (the bit above the spring). I'm going to attack the down pipes with some WD40 and a scotch pad to make them pretty. The area a bit aft however has a lot more corrosion, is there a recommended way to clean this up a bit? Will the corrosion flake off like it did in the less affected areas or am I more likely to poke through? It feels really solid, just has a crusty coating that is pissing me off. Please tell me that it will somehow miraculously restore to a shiny black finish again.. edit for speeling Link to comment Share on other sites More sharing options...
beedub Posted July 15, 2013 Report Share Posted July 15, 2013 Banoffee to the OCD phone please Link to comment Share on other sites More sharing options...
Adam Posted July 15, 2013 Report Share Posted July 15, 2013 I quite like Scotchbrite pads and cutting compound. The stuff in a yellow tube from Halfrauds seems to be ok for stainless headers. Link to comment Share on other sites More sharing options...
BudgetBoy Posted July 15, 2013 Report Share Posted July 15, 2013 not helping am i lol id try something like autosol and scotchbright.. Link to comment Share on other sites More sharing options...
banoffee Posted July 16, 2013 Report Share Posted July 16, 2013 If that was mine I'd be thinking about getting it blasted and refinished. You could try to attack it with abrasives however you may well end up with bare metal. Link to comment Share on other sites More sharing options...
Adam Posted July 16, 2013 Report Share Posted July 16, 2013 Get it ceramic coated! Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 20, 2013 Report Share Posted July 20, 2013 Use a wire brush to take the loose stuff off and sand back to flatten the metal a bit. You're not going to be able to get this flat and smooth so just take the worste off and make a key for paint. Now use a rust killer and leave it overnight. Finally paint it with exhaust paint. When you run the engine for the first time run it for about a minute and allow to it to cool. Then run it for two minutes and cool ... built this up so you cure the paint onto the pipe but exhaust paint is a matt finish not gloss or black chrome. Link to comment Share on other sites More sharing options...
