Mr.Incredible Posted July 8, 2013 Report Share Posted July 8, 2013 So I had the Falco's forks rebuilt with heavier oil and a smaller air gap. I installed the forks with less showing above the yoke than before. It now behaves as I want it to on track and most of the time on the road, however I had a fairly big tankslapper the othe day when accelelerating very hard over a crest with a direction change at the top, and have had a couple of more minor wobbles elsewhere. I appreciate that the big one only happened in a fairly extreme case, but if I can reduce the likelihood of a recurrence then that would be just dandy. Compression and rebound are kind of most of the way in at the moment. Would reducing the rebound damping help? Thinking about it, I think it probably would. Thanks in advance for any advice (relevant to the subject or otherwise). Link to comment Share on other sites More sharing options...
rossm Posted July 8, 2013 Report Share Posted July 8, 2013 Get one of these swingarms, or jusy buy a steering damper Link to comment Share on other sites More sharing options...
Boozybloke Posted July 8, 2013 Report Share Posted July 8, 2013 Shurely, if you've altered the suspension to suit one type of riding, you've compromised it in others? If you dial it back a bit won't it therefore compromise it for the track riding part? I suppose what I'm getting at is maybe leave the suspension but fit a steering damper? Link to comment Share on other sites More sharing options...
Jenny Pryde Posted July 8, 2013 Report Share Posted July 8, 2013 More steering damper. Or less Incredible over corkscrew crests. Link to comment Share on other sites More sharing options...
dansp1 Posted July 8, 2013 Report Share Posted July 8, 2013 Try backing off the rear rebound a little Link to comment Share on other sites More sharing options...
Mr.Incredible Posted July 8, 2013 Author Report Share Posted July 8, 2013 Thanks so far. Steering damper not an option due to cost. Link to comment Share on other sites More sharing options...
