gsxr renegade Posted June 25, 2013 Report Share Posted June 25, 2013 Apologies if this has been done to death already but i was wondering - is a functioning speedo a requirement for the MOT? I've had a look through a few MOT tester manuals that i found online and i can't see a section where they would test the speedo? The only reason i ask is that my speedo cable has broken and a replacement will take a few days to arrive. I could do with getting the bike MOTd ASAP so that can use it to get backwards and forwards to work, and get around on etc. and i've got a spare few days at the end of this week so it'd be ideal to get it MOTd now. The bike does have a speedo, it just doesn't work. I'd obviously fit the new cable as soon as it turned up as it's not a good idea to be riding without knowing how fast i'm going! Also numberplate light - would it fail if mine doesn't work? again, read through a couple of manuals but i couldn't find a section on this. Ta! Link to comment Share on other sites More sharing options...
thefatman Posted June 25, 2013 Report Share Posted June 25, 2013 No it doesn't need a speedo cable. I think you do need a numberplate light, but they possibly won't check it. Can't you fix it if it is broken? Link to comment Share on other sites More sharing options...
gsxr renegade Posted June 25, 2013 Author Report Share Posted June 25, 2013 Brill. Thanks guys. Not sure if the numberplate light is easily fixable- i only noticed it last thing last night. I'm hoping it's just a blown bulb or corroded connections, that shouldn't be too difficult to fix. Link to comment Share on other sites More sharing options...
trackdaybob Posted June 25, 2013 Report Share Posted June 25, 2013 As said, broken speedo not a fail. You will need a bulb for yer no plate though. Link to comment Share on other sites More sharing options...
trumpeteer Posted June 25, 2013 Report Share Posted June 25, 2013 My numberplate light hasn't worked for a couple of years, it's an advisory, as it's against the law or construction and use regs I think, but not an MOT requirement. Link to comment Share on other sites More sharing options...
