El Gringo Posted June 19, 2013 Report Share Posted June 19, 2013 Hi All Bit of an odd one, a mate of mine has a 98 R1, runs sweet as a nut, etc etc. I serviced it about 5 weeks ago, and noticed the coolant was very low, took about 500ml in the Rad and the Overflow bottle was nigh on empty. All filled up and away we go, i ran the bike up to temp and until the fan kicked in whilst i was balancing the carbs and it was fine. He's just rung to say its puked up most of its coolant (He had neglected to tell me that it had done it before i serviced it too) Any ideas? Link to comment Share on other sites More sharing options...
marcaztls Posted June 19, 2013 Report Share Posted June 19, 2013 Where did it puke out of? Overflow hose off the reservoir or under the middle of the sump? Link to comment Share on other sites More sharing options...
El Gringo Posted June 19, 2013 Author Report Share Posted June 19, 2013 Good Question Mark, i shall enquire. Whats the difference? I'm guessing its a seal if its under the sump Link to comment Share on other sites More sharing options...
marcaztls Posted June 19, 2013 Report Share Posted June 19, 2013 Yes if it's under the sump it'll be the water pump seal itself and the coolant will be bypassing that and exiting through the drain hole in the middle of the sump. If it's coming out of the overflow hose then something's causing pressure to build up, be that a head gasket leak, blockage, air lock etc. Link to comment Share on other sites More sharing options...
El Gringo Posted June 19, 2013 Author Report Share Posted June 19, 2013 Hmmm we shall see, I would hazard that it runs too well to be the head gasket, and i burped the hoses when i refilled it (been caught with that one before) I shall be back presently Link to comment Share on other sites More sharing options...
El Gringo Posted June 19, 2013 Author Report Share Posted June 19, 2013 And as if by magic.... He reckons it was from underneath so sounds like the water pump seal. Would it only do it under pressure? Link to comment Share on other sites More sharing options...
marcaztls Posted June 19, 2013 Report Share Posted June 19, 2013 Don't bet against it. Bikes can feel perfectly normal while venting just enough chamber pressure to force coolant out. Check the cap is sealing first and foremost. I'm just about to leave work and don't have very good phone signal at home so may not be able to answer until the morning. Link to comment Share on other sites More sharing options...
marcaztls Posted June 19, 2013 Report Share Posted June 19, 2013 Possibly yes, but if it is coming from underneath then it's the pump mechanical seal. Easy enough job, rad and sump off, clutch out and pump can be removed. Link to comment Share on other sites More sharing options...
El Gringo Posted June 19, 2013 Author Report Share Posted June 19, 2013 Cracking, Many Thanks Mark, I'll have a look Cheers Chris Link to comment Share on other sites More sharing options...
marcaztls Posted June 19, 2013 Report Share Posted June 19, 2013 No worries. Post back what you find Link to comment Share on other sites More sharing options...
El Gringo Posted June 21, 2013 Author Report Share Posted June 21, 2013 Mechanical Seal and the other one ordered - will report back after Sunday Link to comment Share on other sites More sharing options...
MonkeyJim Posted June 21, 2013 Report Share Posted June 21, 2013 And as if by magic.... He reckons it was from underneath so sounds like the water pump seal. Would it only do it under pressure? the overflow pipe from the coolant expansion bottle runs down behind the back of the cylinder head / upper crankcase and vents down into the bellypan, it's held by a clip on the front of the genny engine case (which also holds the fuel tank overflow vent and fuel tank breather) I would hazard a guess that when he says it's 'coming from underneath' and 'puking its coolant out' it will be from the expansion bottle overflow. when it's the water pump seal it usually drips out (from the drain hole bang in the middle of the sump) need to get the bellypan off and ideally the RHS infill / fairing panel to see where the coolant's actually coming from. my money's on the expansion bottle overflow hose, caused by an airlock (has the coolant been changed recently?) or possibly the radiator cap not holding pressure. Link to comment Share on other sites More sharing options...
