2Smoke Posted June 4, 2013 Report Share Posted June 4, 2013 The old LDD Z500 has started showing its oil light while at idle after a ride. Level is okay, goes off with anything about tickover. Ok when cold. Sign of a pump dying or maybe a faulty switch? Link to comment Share on other sites More sharing options...
Stephenrc45 Posted June 4, 2013 Report Share Posted June 4, 2013 Con rod side faces would be my guess. Try the switch first I guess as it's cheap. Link to comment Share on other sites More sharing options...
Superdunc Posted June 4, 2013 Report Share Posted June 4, 2013 Does the oil pump have a pressure relief valve you can get to easily? Might have some shit under the seat or you might have to shim the spring. Link to comment Share on other sites More sharing options...
2Smoke Posted June 4, 2013 Author Report Share Posted June 4, 2013 I'm not sure, have ordered a sump gasket so will whip the pump out after I've done the top end rebuild and see what's going on. Might have to put some tape over the light or something.. can't be doing with it breaking down! Link to comment Share on other sites More sharing options...
Evilchicken0 Posted June 4, 2013 Report Share Posted June 4, 2013 I'd go with turning the idle speed up. It's an oil pressure light so it's better off than on. Link to comment Share on other sites More sharing options...
lorenzo Posted June 4, 2013 Report Share Posted June 4, 2013 I'm sure an MOT tester can excuse you a 1500rpm idle for a charitable cause, can't he? Link to comment Share on other sites More sharing options...
2Smoke Posted June 4, 2013 Author Report Share Posted June 4, 2013 MOT? The bikes have to be legal for the run?? Link to comment Share on other sites More sharing options...
