Get_some Posted June 2, 2013 Report Share Posted June 2, 2013 Bike has been sat for 3 years, new battery fitted and it wont start. The battery fully charged, the engine just wont fire. I assume fuel is the problem? Will running some motul fuel system cleaner clear it? Would you drain the engine and replace oil and filter too? Link to comment Share on other sites More sharing options...
levo Posted June 2, 2013 Report Share Posted June 2, 2013 New plugs,new fuel and a can of easystart.......after you have cleaned carbs.(if it has any) and a little patience. Link to comment Share on other sites More sharing options...
Get_some Posted June 2, 2013 Author Report Share Posted June 2, 2013 Thanks Levo, is fuel injected. It started last week and was running fine if a bit smokey, so I turned it off, few days later the battery was drained (which I put down to a weak battery being drained by the immobliser). Hoping its just injested some of the bad fuel. Link to comment Share on other sites More sharing options...
levo Posted June 2, 2013 Report Share Posted June 2, 2013 A injector type cleaner would be good .....but I reckon a clean out of the fuel tank ,a gallon of shell super/.optimax/v power and she will light up with ease. Link to comment Share on other sites More sharing options...
Get_some Posted June 2, 2013 Author Report Share Posted June 2, 2013 Cheers dude Link to comment Share on other sites More sharing options...
Get_some Posted June 2, 2013 Author Report Share Posted June 2, 2013 Can of motul fuel cleaner in with full tank of fuel, she still won't fire:( Link to comment Share on other sites More sharing options...
levo Posted June 2, 2013 Report Share Posted June 2, 2013 Did you clean the tank out? Did you use new fuel? Did you use the whole tin of cleaner in the tank? New plugs? Try new plugs Clean out the tank Brand new fuel Spray easy start in the air box and try again Link to comment Share on other sites More sharing options...
levo Posted June 2, 2013 Report Share Posted June 2, 2013 Try owning a nc30 and not running it for a while.....utter nightmare. Link to comment Share on other sites More sharing options...
Get_some Posted June 2, 2013 Author Report Share Posted June 2, 2013 She's going now, whole tin went in, think patience was the missing element, thanks again Link to comment Share on other sites More sharing options...
levo Posted June 2, 2013 Report Share Posted June 2, 2013 Hip hip hooray..nice one Link to comment Share on other sites More sharing options...
