Yamaha Caliper 'blue Spot' Removal Tool
rd84
Hi,
For Yamaha owners doing caliper restoration work I spotted this 'Blue Spot' removal tool on Ebay...........
http://www.ebay.co.uk/itm/YAMAHA-BLUE-SPOT-CALIPER-KEY-SPANNER-AIRCRAFT-GRADE-ALUMINIUM-/111067704587?pt=UK_Motorcycle_Parts_13&hash=item19dc26ad0b
Hopefully this might be useful to someone on this forum.
I've just ordered one so hopefully it's good.
Cheers
Paul
i got one of those a few years ago-worked excellent!!i tend to pack it out with a bit of tape to make the fit tighter and to try to minimise marks-but does exactly as it says
Hi,
Got the tool today - nice quick delivery - it's quite a good fit but as said above I'd recommend some thin tape to give a tighter fit and to minimise scratching the anodised cover. As far as the actual removal goes treat it like a normal slightly seized bolt and apply some heat as suggested above to break any corrosion and minimise the force required to undo the blue spot cover.
Cheers
Paul
Am I right in thinking with these callipers, that removing the plug allows you access to push the pistons out? If so all callipers should be designed that way!
Thats correct Barry-not sure if Yamaha endorses it -but it works-best to heat them a little as they have a locking compound judging by the way the anodised portion undoes
Of course you don't need any tool to rebuild the calipers, just pump one pair of pistons out at a time. I never have removed the plugs.
They use plugs so they can machine the piston bores conventionally ( from one side ) rather than using god knows what to machine a proper monoblock caliper.
I usually do that, but have suffered from a complete siezure and it hasn't worked.
