Accossato M/c Banjo
gavd
Hey up quick question, attempting to fit my new accossato m/c to my 06 zx6, unfortuantely the banjo bolt from the original m/c seems to be the wrong thread for the new m/c, anyone experienced this? guess i just neep to buy an appropriate banjo bolt, ta
I had this problem as well, when I came to fit my lovely Accossato mastercylinder (from Fatbloke) ,I found my Yamaha banjo was a different thread.
You need an M10 x 1.00 thread.
I needed a brake light switch as well so I bought This
Hope this helps,
Mike
Yep, new banjo required by the sounds of it. They are usually called coarse or fine thread, if you're not sure which you've got and you're going to a bike shop then take the bolt with you and say 'not this thread!'
Think mine was very fine. I used the one off my old Brembo MC....
Japanese master cylinders are usually m10x1.25, 'm10 fine'.
Italian master cylinders are usually m10x1.00, which is also m10 fine, but the other fine.
