Pod Filters On Cv Carbs.
Alex.
Hi Guys,
I'm currently building a Cafe Racer from a 1989 Yam XJ600, using pod filters. Performance is not the driving factor, as I have other bikes that are much faster than an XJ could ever be! The pods just fit with the look of the bike.
I know that the carb settings will need to change, but what would be a good baseline to start from?
The standard spec for the Mikuni BS32 carbs is:-
Main Jet - 105
Pilot Jet - 40
Main Air Jet - 70
Jet Needle Clip - 3 (although I do not remember the clip being adjustable on the needle)
Needle Jet - N-8
Any help would be greatly appreciated, I'm getting close to the end of the initial build!
Alex.
We did a ropey XJ550 a year or so ago and fitted foam pods to it (not those awful chrome capped mesh ones!) and ended up just raising the needles by a notch. That cleaned it up enough to make it rideable* and it sounded pretty good. It's a cheap (free!) fix and will give you a decent starting point. You might end up needing to bugger about with the main jet size but I wouldn't (personally) bother messing around with much else.
* 'rideable' as in 'no gaping flat spots needing tons of clutch slip to pull away' :lol:
I would lift the needles a notch to begin with. If there are no notches then get 4 M4 flat washers and put them under the top of the needles where they come through the diaphragm. One on each carb...
I'd also probably go to 115 as a starting point on the mains ideally. Maybe also consider a 45 pilot jet?
CV carbs aren't ideal to run with pod filters so you will always find a flat spot or imperfect fuelling somewhere.
Thanks guys, I'll lift the needles and see about some jets.
Can't wait to get her on he road! :icon_bounce:
Alex.
