Two Stroke Help Please
tootall
I know basically fuck all about 2T engines and I'm trying to get a wee qr50 running.
Its got fuel, oil and spark. Had the head off and barrel looks fine and piston top clean.
No amount of kicking over is producing any sign of life.
Carb off for a clean out next but anything else I should be checking?
Ta
J
Not had the pipe off, will have a look at that.
Feels ok for compression.
Plug isnt getting wet no matter how long I spend kicking it over.
Vacuum tap ?
Is there a prime position ?
Vacuum tap ?
Just on/off tap. Fuel pisses through when in on position (and you got the hose off, all over nice new trainers!)
Don't have a cigarette just yet then !
Has the carb got a drain screw/plug ?
If fuel is definitely getting into float bowl , it must be blocked jets .
When was it last run ?
yeah drains out nicely, carb off tomorrow then.
Last run about 2 years ago I think
And yeah, had a fag in my mouth at the time :D
Pulled the choke out?
Squirt some brake cleaner up the carb and and kick it over. If it fires you need to strip the carb . Probably full of manky old 2stroke mix.
