Brembo Goldie
Evilchicken0
I had a bit of an issue bleeding the Bimota's clutch master cylinder. It's a Goldline like the th Ducati 916 etc finally I fitted a banjo with a bleed nipple used my vacumn thing wiggled it all, took the lever off and pumped it with 1/4" extension bar. That pushes the piston further than the lever and seemed to do the trick.
Only problem is I knackered the dust seal. There doesn't seam to be an obvious way to replace them, can they be replaced or is this a Brembo don't make them situation ???
I think it's a struggle for us "normal" punters to get the seals.
I've not used them, but on Motoforum Race Spares UK are recommended for this work.
01704 840825
07808 476377
