leighbike Posted April 23, 2013 Report Share Posted April 23, 2013 as it says C6h no mods, stock exhaust, first ride of the year to work and FI light on...any ideas? Link to comment Share on other sites More sharing options...
MonkeyJim Posted April 23, 2013 Report Share Posted April 23, 2013 The light has come on to warn you that there is no race can fitted Link to comment Share on other sites More sharing options...
leighbike Posted April 23, 2013 Author Report Share Posted April 23, 2013 Ha! that must be it.... fuckin 'lectrics... Link to comment Share on other sites More sharing options...
BudgetBoy Posted April 23, 2013 Report Share Posted April 23, 2013 as it says C6h no mods, stock exhaust, first ride of the year to work and FI light on...any ideas? butterfly in the exhaust is probably stuck of needs looking at. Forgot to add.. Get this and be done with it.. http://www.speedycom.co.uk/shop/product.php?productid=18697&cat=905&page=1 Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted April 23, 2013 Report Share Posted April 23, 2013 Yep,what budget boy says-common fault with them-they seize open!its unstrippable so either give it a good soaking or see if you can source a plate to fit to the servo pulley to trick it into thinking the cables are attached.Akrapovic used to do one. Link to comment Share on other sites More sharing options...
leighbike Posted April 23, 2013 Author Report Share Posted April 23, 2013 lovely boys..i'll get the wd40 out. Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted April 23, 2013 Report Share Posted April 23, 2013 DO NOT move the pulleys yourself!only let them rotate by switching the ignition off and on.The cogs in the servo are only plastic & it's very easy to strip the teeth off it! Link to comment Share on other sites More sharing options...
