El Gringo Posted April 16, 2013 Report Share Posted April 16, 2013 Hi All Just wanted to check something with the material gurus. I need to make some reducers to take a rear caliper bracket, wheel spacers and sprocket carrier bearing insert from 25mm to 20mm diameter. It's so i can run a wheel that currently has a 25mm spindle on a 20mm spindle, i have found the bearings but wanted to know if standard 6082 T6 ally tube will be ok to use as inserts for the various reducers? I can probably remake the actual wheel spacers but the caliper bracket and bearing insert need reducing too. Would it be ok? Cheers Chris Link to comment Share on other sites More sharing options...
porter_jamie Posted April 16, 2013 Report Share Posted April 16, 2013 yes, 6082t6 (HE30) will be fine, its the most common 'engineering' grade ally so most places will have lumps of it laying around. Link to comment Share on other sites More sharing options...
El Gringo Posted April 16, 2013 Author Report Share Posted April 16, 2013 Cracking, Cheers Jamie. PS I'll kick my mates arse about that CAD drawing for the bracket Link to comment Share on other sites More sharing options...
off road rob Posted April 16, 2013 Report Share Posted April 16, 2013 Plus one on the HE30 grade of aluminium, HE15 would do a similar job if need be also. Link to comment Share on other sites More sharing options...
