CRM Posted April 14, 2013 Report Share Posted April 14, 2013 got an issue on my CBR6 changed the front wheel and disks a week ago, and noticed a slight weep from one of the braided hoses. However before i changed anything i did notice the brake lever felt fine as normal, but push the bike a few feet or 10 and the lever comes back to the bars. pump it up and its fine again - until the next time it moves So replaced the calipers (with some spare rebuilt ones ready to go) new pads, rubber OE hoses and master cyl - and it does the same. Got what seems all the air out, a good firm lever, and if i push it forwards a bit the lever goes to mush. So i assumed the disks were bent - but no, wheel and disks good, spin them on the balancer and all is true, no drag while pushing about or anything very odd. any ideas ? Link to comment Share on other sites More sharing options...
chi kung Posted April 14, 2013 Report Share Posted April 14, 2013 I had a similar issue to this once. In my case it was a bleed nipple not seating down fully and letting air back in. Link to comment Share on other sites More sharing options...
Jenny Pryde Posted April 14, 2013 Report Share Posted April 14, 2013 Witchcraft. Clear case of brakes possession. Does your milk go sour quickly too? Have you tested your next door neighbour for witch-like traits? Link to comment Share on other sites More sharing options...
Mahatma Posted April 14, 2013 Report Share Posted April 14, 2013 Try bleeding the brake,but if that don't work it may be the master cylinder which is shot... Hope you find it out Link to comment Share on other sites More sharing options...
CRM Posted April 14, 2013 Author Report Share Posted April 14, 2013 Well it appears one of the discs is shagged, i just put the old (tatty and rusty looking) ebc pro lites back on and all is well. the wobble on the disk is enough to force the pads back. Link to comment Share on other sites More sharing options...
krazyk Posted April 14, 2013 Report Share Posted April 14, 2013 Some of the old Yam mc's used to keep a pinhead sized bubble at the piston. Gave that sort of feeling . Hth kk Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 14, 2013 Report Share Posted April 14, 2013 Clean the ProLites up and use some silver wheels paint on them Link to comment Share on other sites More sharing options...
lorenzo Posted April 15, 2013 Report Share Posted April 15, 2013 Well it appears one of the discs is shagged, Dead easy way to see if one disc is knackered is to put it on a front stand and spin the wheel while looking at where the disc runs through the caliper. As there's only about 3mm gap between the two anyway and wobble becomes quite apparant. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 15, 2013 Report Share Posted April 15, 2013 Dead easy way to see if one disc is knackered is to put it on a front stand and spin the wheel while looking at where the disc runs through the caliper. As there's only about 3mm gap between the two anyway and wobble becomes quite apparant. ... and your brakes feel like there's air in them Link to comment Share on other sites More sharing options...
CRM Posted April 15, 2013 Author Report Share Posted April 15, 2013 did exactly that. backed the pads off a couple of mm, and spun, and sure enough left hand disc had a wobble of i reckon a couple of mm - enough to push the pistons back hence the shit brakes. new discs required as the prolites are horrible. Link to comment Share on other sites More sharing options...
