Bickers Posted April 10, 2013 Report Share Posted April 10, 2013 I have just picked up a very cheap 5000 mile Bandit... It had a dead battery, after fitting a new 'un the alarm has just gone mental and now I am deaf. I tried resetting the fob by holding both buttions down for 20 seconds a few times, but it continued to remove the rest of my hearing. I have now removed the internal battery, fuse and wiring and will leave it for the day to try and reset it. Has anyone else had a similar problem or have any usefull or sarcastic advice to offer in this situation?!?!?! Ta Link to comment Share on other sites More sharing options...
crumpy Posted April 10, 2013 Report Share Posted April 10, 2013 Rip the fucker out, put it in the bin. Standard procedure now on any bike I buy that has an alarm fitted. Link to comment Share on other sites More sharing options...
Bickers Posted April 10, 2013 Author Report Share Posted April 10, 2013 Is this a nightmare of a job for a home mechanic? Link to comment Share on other sites More sharing options...
trackdaybob Posted April 10, 2013 Report Share Posted April 10, 2013 Rip the fucker out, put it in the bin. Standard procedure now on any bike I buy that has an alarm fitted. +1Fortunately I'm old enough not to need to bother with alarms to save £10 on my insurance Link to comment Share on other sites More sharing options...
overload Posted April 10, 2013 Report Share Posted April 10, 2013 +1 on ripping it out. Not hard to do. Disconnect battery. Take seat bodywork off and unveil the wires leading from the alarm down to the battery and solenoid. Remove alarm wires and reconnect wires which were previously occupied by alarm and then tidy the loom up. Link to comment Share on other sites More sharing options...
Doug_R1 Posted April 11, 2013 Report Share Posted April 11, 2013 I removed mine, I was expecting all sorts of loom issues, but it was only attached to the fusebox (power source), the indicators and the rear numberplate light!!! Simplest job I've done in ages, although I resent having paid a Datatool approved installer good money for fitting it. It's only function appears to have been as an expensive tilt sensor. Link to comment Share on other sites More sharing options...
grantmotox Posted April 12, 2013 Report Share Posted April 12, 2013 as said rip it out. Email datatool for a installation guild, this will allow you to know which wires do what. Link to comment Share on other sites More sharing options...
oggy411 Posted April 14, 2013 Report Share Posted April 14, 2013 I had the same problem recently with mine but to add insult, when i did manage to get the fucker to behave for long enough to run the bike, at high revs, the fucker would cut the ignition momentarily, causing my bollocks to smash into the tank, before re-connecting and throwing me backwards again. Needless to say, its now a collection of smashed plastic and circuitry at the bottom of the dustbin. Link to comment Share on other sites More sharing options...
Leighio Posted April 15, 2013 Report Share Posted April 15, 2013 Have a picture somewhere of how to short out the plug connecting to the alarm module that will allow the bike to run Link to comment Share on other sites More sharing options...
BudgetBoy Posted April 16, 2013 Report Share Posted April 16, 2013 Take it out.Not hard really ive done a few (one for Bigkingy of this parish). Follow each wire (one at a time) remove it and solder any joints and use heatshrink, then tape it up. Took me about 2 hours iirc to do BK's Just take your time and you will do it. Link to comment Share on other sites More sharing options...
