kanerdog1x1 Posted April 6, 2013 Report Share Posted April 6, 2013 I've done a bit of a search but couldn't find anything on here. Searching with google showed various plans, both hand held and those bigger set ups using a tank/vessel to hold the sand. Does anyone here have experience of making one that works? And, what type of sand to I need, does that matter? Ta muchly. Link to comment Share on other sites More sharing options...
BudgetBoy Posted April 6, 2013 Report Share Posted April 6, 2013 Dont use sand as silicosis will ruin your lungs. http://en.wikipedia.org/wiki/Silicosis I also looked into making a "Home made" blaster, but i ended up buying the proper thing in the end. Link to comment Share on other sites More sharing options...
blur1 Posted April 7, 2013 Report Share Posted April 7, 2013 Dont use sand as silicosis will ruin your lungs. http://en.wikipedia.org/wiki/Silicosis I also looked into making a "Home made" blaster, but i ended up buying the proper thing in the end. 'Sillycosis'. Isn't that what anyone that actually pays money for a Ducrappi has? Smart people "end up buying the proper thing in the end"............YAMAHA! Link to comment Share on other sites More sharing options...
tootall Posted April 7, 2013 Report Share Posted April 7, 2013 I've built a couple. Both syphon fed and pressure pot type. What do you want to know? Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted April 7, 2013 Author Report Share Posted April 7, 2013 I think I'm gonna make a pressure pot type. Can I just buy cheap sand from b&q? Oh, and regarding silicosis, I'm a motorcyclist so worry very little about the consequences. I work with aluminium and you can contract a condition from that too, I forget what it's called...... Link to comment Share on other sites More sharing options...
blur1 Posted April 7, 2013 Report Share Posted April 7, 2013 I think I'm gonna make a pressure pot type. Can I just buy cheap sand from b&q? Oh, and regarding silicosis, I'm a motorcyclist so worry very little about the consequences. I work with aluminium and you can contract a condition from that too, I forget what it's called...... It's called 'making you really good at working with metals'! As for the sand.You should be able to buy it at a dedicated sandblast supplier. Link to comment Share on other sites More sharing options...
Adam Posted April 7, 2013 Report Share Posted April 7, 2013 I thought you would've had a sand blaster at work? You can get aluminum oxide powder from machine mart I think. I built a blasting box when I was in high school, it was only going to be temporary because I didn't have space to keep it. It was just made in chip board. The only problem I had was that the perspex screen got scratched quite easily and became opaque. Also yeah, I believe there is a link between Alzheimer's and aluminium. Link to comment Share on other sites More sharing options...
VanWinkle Posted April 7, 2013 Report Share Posted April 7, 2013 I was thinking about this the other night, isnt making the box leak proof a big problem, or is the blasting box used out doors?.. Link to comment Share on other sites More sharing options...
BudgetBoy Posted April 7, 2013 Report Share Posted April 7, 2013 If its just a hobby one get this.. For the sake of £90 you have all the hard work done for you.(Or steal use the design) http://www.ebay.co.uk/itm/NEW-10-Gallon-Pot-Bead-Shot-Sand-Blast-Blaster-Blasting-/130427874115?pt=UK_Air_Tools_and_Compressors&hash=item1e5e1b6b43 If you are making a blast cabinet yourself then use silicone on all the joints when you assemble and then after its built on the cornersThe good thing about the metal unit is the corners are all bent over so they wont leak but i have also siliconed mine just to be sure. Personally i will be using Glass bead or ally oxide..If you are going to use sand make sure it it screened kiln dried sand..make sure you keep your sand completely dry or it will clog your gun. Link to comment Share on other sites More sharing options...
