moose_ Posted April 1, 2013 Report Share Posted April 1, 2013 Finally after about a year of rough idling I've managed to blag a loan of some Carbtune pro vacuum gauges to try and balance my throttle bodies. Now, I'm fairly mechanically inept but managed to get them on and was getting a reading quite close across all 4 pots. Cylinder 1 was reading slightly out from the rest and was jumping about a bit so I tweaked the screw which brought it in line with the rest but it was still jumping about a bit. Cylinder 3 was twitching a wee bit and the other two were rock solid. Would this indicate the valves need adjusted or is there something else I should be looking at? The bike is a GSXR 1000K3 if that matters Cheers Link to comment Share on other sites More sharing options...
BudgetBoy Posted April 1, 2013 Report Share Posted April 1, 2013 As long as you get them within 2hg of each other that will be ok. i have the carbtune and they do jump about on some bikes.. you need a steady idle.. have you increased the idle up to about 2k? Doing it on idle wont help matters, the carbtune needs a steady throttle. Balance 1&2 so they are equal, then balance 3&4 so they are equal , then balance them together. Link to comment Share on other sites More sharing options...
moose_ Posted April 1, 2013 Author Report Share Posted April 1, 2013 I was trying it on idle going by the suzuki manual. I'll try again with more revs Thanks Link to comment Share on other sites More sharing options...
Conica Posted April 1, 2013 Report Share Posted April 1, 2013 Should've bought a Dyson. Link to comment Share on other sites More sharing options...
Thom_1991 Posted April 1, 2013 Report Share Posted April 1, 2013 Does this make a big difference with efi bikes? It was night and day on the (carbed) Fazer. Link to comment Share on other sites More sharing options...
moose_ Posted April 1, 2013 Author Report Share Posted April 1, 2013 You sure the dampers were in the vacuum hoses? nope, not sure at all. I borrowed the gauges from a mate and just plugged the hoses onto the throttle bodies. I did spy some black plastic bits in the box but just thought they were adaptors. Link to comment Share on other sites More sharing options...
moose_ Posted April 1, 2013 Author Report Share Posted April 1, 2013 Don't think there was. I'm going to try again tomorrow so will double check. Thanks Link to comment Share on other sites More sharing options...
