crumpy Posted March 27, 2013 Report Share Posted March 27, 2013 I need someone to weld my hornet exhaust bits together at short notice, in the South London/Surrey kind of area. Any recommendations? Should be a fairly simple job. The ink pip needs a bit of the straight mid section removed and I need to weld the can to the link pipe, as the current inlet part is too big of a diameter (though I can find an alternate solution to this bit if it is problematic). I can do the cutting and prep work. Link pipe is a stainless bit from an aftermarket hornet exhaust (53mm-ish), and the end can is an open race micron from an unknown source (65mm (the short bit of pipe tapers in to about 50mm just inside the can though). Ta Link to comment Share on other sites More sharing options...
4tgp Posted March 27, 2013 Report Share Posted March 27, 2013 Hi mate, I can do it. http://pbmagforum.co.uk/index.php?showtopic=37959 we are in Essex SS15 6SS. you could bring it over one evening and drink tea while you wait. See my supermono build thread for stainless exhaust welding. You got any pics? Link to comment Share on other sites More sharing options...
crumpy Posted March 27, 2013 Author Report Share Posted March 27, 2013 I'll just take some pics now. How soon do you think you might be able to do it? I have some running issues I need to sort so would ideally want to do asap so I have some time to get it all good before the weekend. Link to comment Share on other sites More sharing options...
crumpy Posted March 27, 2013 Author Report Share Posted March 27, 2013 This is the link pipe. I'll cut out part of the straight section, approximately the distance between those two studs. then I'll just need the two pieces welded back together. And then I need this bit (53mm)... Connected to this bit (65mm pipe section, but goes down to 50m ish just inside the can) If this second weld isn't possible or is difficult I can find another solution like packing it out and clamping it on. Cheers Link to comment Share on other sites More sharing options...
crumpy Posted March 27, 2013 Author Report Share Posted March 27, 2013 Here's a couple slightly more useful pics of the can/linkpipe connection. I can cut off the pipe section from the can in prep or whatever else you think I should do depending on what method you might think best. Link to comment Share on other sites More sharing options...
crumpy Posted March 29, 2013 Author Report Share Posted March 29, 2013 Cheers lads, it's spot on. Link to comment Share on other sites More sharing options...
bikemike Posted March 29, 2013 Report Share Posted March 29, 2013 Pics please! I love welding pron me. Link to comment Share on other sites More sharing options...
crumpy Posted March 29, 2013 Author Report Share Posted March 29, 2013 Alright, I'll get some pics up later when I update the bike thread. Link to comment Share on other sites More sharing options...
