Rick448 Posted February 17, 2013 Report Share Posted February 17, 2013 Will a SRAD750 gearbox fit a year 2000 750Y motor? Mine has problems with second gear and I have replaced the motor with a used one. I want to fix the other up as a spare but am struggling to find a box though there seems to be a few SRAD ones about. Link to comment Share on other sites More sharing options...
lorenzo Posted February 18, 2013 Report Share Posted February 18, 2013 Have a look here, then have a look here, and see if the part numbers match up and if you can rustle together a mix and match of the two? Link to comment Share on other sites More sharing options...
Rick448 Posted February 18, 2013 Author Report Share Posted February 18, 2013 Thanks. Ill check that out later. Link to comment Share on other sites More sharing options...
Superdunc Posted February 18, 2013 Report Share Posted February 18, 2013 Have you stripped the 750y gearbox yet? It might only be a few small parts which need replacing. In which case you'd be far better off buying new parts, happy in the knowledge that you've fixed it and not bought a second hand gearbox with the samr worn out parts. Link to comment Share on other sites More sharing options...
speedy sie Posted February 18, 2013 Report Share Posted February 18, 2013 simple no they are difrent,but some parts will fit,but not the full gear box...if i ramaber right...ass is still sore Link to comment Share on other sites More sharing options...
Rick448 Posted February 18, 2013 Author Report Share Posted February 18, 2013 Thanks all. Not stripped it yet. Ill do that when I get a chance. Link to comment Share on other sites More sharing options...
