chrisexup Posted February 16, 2013 Report Share Posted February 16, 2013 Does anyone know the spring rate of the standard SZR660 shock? Link to comment Share on other sites More sharing options...
szrdave Posted February 17, 2013 Report Share Posted February 17, 2013 Hi Chris. Just had a look at mine, but the rate is not marked on the spring. Why do you want to know? Link to comment Share on other sites More sharing options...
porter_jamie Posted February 17, 2013 Report Share Posted February 17, 2013 Racetech website is your friend Link to comment Share on other sites More sharing options...
porter_jamie Posted February 17, 2013 Report Share Posted February 17, 2013 Ok it's not on there.. Link to comment Share on other sites More sharing options...
chrisexup Posted February 17, 2013 Author Report Share Posted February 17, 2013 Hi Chris. Just had a look at mine, but the rate is not marked on the spring. Why do you want to know? i borrowed an SZR spring for a project, and it's the ideal weight, but doesn't fit the damper body i'm going to use. I need to know which Faulkner spring to get. I got a 600lb/in one yesterday, but that is still too light, i will see if i can swap it for a 700lb/in spring. Link to comment Share on other sites More sharing options...
