Engine Mount Damage
Rainer
This is the front RHS engine mount of my SP1. The crash bung base to the right of the picture was bent up into the rad and, as I feared, has also cracked the engine mount. I'll replace the rad, but is the engine mount fixable?
It doesn't look too bad from that angle...
Once welded up and sorted out, it'll probably be stronger than the original cast area(?)
:eusa_think:
Speak to a specialist frame builder matey, cast can go as brittle as fuck when it's welded.
I'd maybe look at taking the mount off completely and having one machined up that you can bolt to the frame.
How do you think they attached it to the frame rais in the first place? ;)
By a specialist frame builder.
Or a robot welder as quickly as possible. Manufacturers select materials for bike frames that are going to make the frame a cheap and simple as possible to manufacture, very very few production bikes are made from heat treatable alloys, so welding a frame would be perfectly within the the realms of any decent alloy welder. Yes care has to be taken to select the correct rod and prepare the job correctly, but it's no diiferent if you welding bike frames or street futniture.
Some cast don't weld very well at all but a casting that is already welded to a structure shuoldn't be an issue.
Edit: What Mille said would be the correct way to do it in an ideal world.
Have you fuckers never heard of 60 second araldite?..............
Or, in keeping with the other thread today, why not replace with a nice shiny ducati?...........:-p
