marcuszs Posted January 20, 2013 Report Share Posted January 20, 2013 I have a tyga nc35 carbon mudguard i want to cut down to remove some damage from , Here is the damaged one , stickers on the front cover the damage Here's one i have which i want to copy would the edges need to be sealed once cutting and what should i use to cut it? Link to comment Share on other sites More sharing options...
porter_jamie Posted January 20, 2013 Report Share Posted January 20, 2013 i've used a cutting disk in an angle grinder before. the dust gets in the motor eventually and fucks it up though. Link to comment Share on other sites More sharing options...
alexp5 Posted January 20, 2013 Report Share Posted January 20, 2013 ^ What he said, or a Dremel. I reshaped a c/f hugger once with an air bodysaw which was probably the best method... Whatever you use - wear a dust mask, and it helps to use a plant spray mister thing to damp the dust down. You really don't want to be breathing in that crap. I never sealed the edges and it looked ok. I did final shaping with a file and emery cloth to get a nice smooth edge. I don't suppose it would hurt to dab on some lacquer though. edited due to twitchy trigger finger. Link to comment Share on other sites More sharing options...
si.likes.guiness Posted January 20, 2013 Report Share Posted January 20, 2013 i have a proper carbon saw,its like a hacksaw but with a round blade,fantastic little thing,i cant remember off hand where i got it from though. Link to comment Share on other sites More sharing options...
speedy sie Posted January 20, 2013 Report Share Posted January 20, 2013 dremeel with diamond cutting disk in done this many times and all good Link to comment Share on other sites More sharing options...
Bens pies Posted January 20, 2013 Report Share Posted January 20, 2013 As said a Dremel or thin cutting disc on a small grinder, then shape with needle files and emery paper to a smooth finish, just be carefull not to scratch the lacquered surface, I've never sealed the edge after modifying a carbon part, I live near Fibrelyte so have got alot of carbon bits. Link to comment Share on other sites More sharing options...
lorenzo Posted January 20, 2013 Report Share Posted January 20, 2013 Clear laquer will seal it up a treat. I've cut plenty of carbon in the past with just a hacksaw and it's come out looking pretty good. I'd whack a load of masking tape over it so you can draw your nice clear line of where you want to cut it and then just go with a hacksaw blade. Carbon's a peice of piss to cut so long as your blade's half decent, it's only when you start getting kevlar involved that it gets tricky. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted January 21, 2013 Report Share Posted January 21, 2013 I always use an angle grinder with a cutting disc and finish with a second hand i.e. slightly worn linishing/flapper wheel in the grinder. The sharp edge of a convex file will sort out the loose strands of Kevlar if there's any buried in there. If the edge chips up you can finish with a little resin to tidy it up, flatting back and polish will seal the edge nicely. Link to comment Share on other sites More sharing options...
