Exhaust Gaskets
dai1984
Morning,
I am fitting a full system to the R1 and was planning on just reusing the old ones. However I did some research and will replace them instead.
What is the difference between the copper ones and the stainless steel ones on ebay? I thought they were meant to be crush washers hence made from soft copper.
Cheers,
Dai
As you say the copper ones crush to form a seal, the others do a simila thing but don't crush so much.
It's down to you what you use - I use the copper ones, I did use the others but found they were breaking up a bit when I took the system off. Use some coppaslip to hold them while you put the downpipes on.
