Kawasakifreak Posted January 5, 2013 Report Share Posted January 5, 2013 My project GPz750 Unitrak has light rust inside the fuel tank. Vinegar or electrolysis ? Link to comment Share on other sites More sharing options...
dansp1 Posted January 5, 2013 Report Share Posted January 5, 2013 http://www.bilthamber.com/fuel-tank-cleaning-kit I used this on my 46 year old saab fuel tank which i honestly thought was fit for scrap, it came out like new inside Link to comment Share on other sites More sharing options...
dansp1 Posted January 5, 2013 Report Share Posted January 5, 2013 ]http://www.flickr.co...02/8349876133/] My two stroke wasaabi earlier today Link to comment Share on other sites More sharing options...
hotballs Posted January 5, 2013 Report Share Posted January 5, 2013 i filled 2 tanks up with the cheapest white vinegar from the supermarket and it really cleaned them out. you have to leave it in for about 5 days and if the rust is severe then if you can get your hand in with a stiff brush thats good too, but the vinegar etched out all the rust from my tanks. Link to comment Share on other sites More sharing options...
BudgetBoy Posted January 5, 2013 Report Share Posted January 5, 2013 White vinegar is stronger than the brown stuff, and Apple cider vinegar is even stronger (5% acid). Cheap coke will also have the same effect.. electrolysis is also good. I did FlatTels tank and one for ZXRdave on this forum.Ask them how they are now..And yes that is hard rust in Tels tank.. he thought it was only fit for the bin. Also remember Ying & Yang.. use baking soda when you use any acid to neutralize it. Before:- After:- Link to comment Share on other sites More sharing options...
dansp1 Posted January 5, 2013 Report Share Posted January 5, 2013 The "after" shots with the Bilt-Hamber gear are bright shiny steel, sadly i didn't take any pics before or after Link to comment Share on other sites More sharing options...
Richy Posted January 6, 2013 Report Share Posted January 6, 2013 Citric acid works well. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted January 6, 2013 Report Share Posted January 6, 2013 I bought a kit and used it. It took 24 but I left it for 48. It cleaned the tank inside and cost about 20 Link to comment Share on other sites More sharing options...
Kawasakifreak Posted January 6, 2013 Author Report Share Posted January 6, 2013 Thanks folks,. Evil chicken & Dansp1 - does the built hammer kit come with everything you need ? Link to comment Share on other sites More sharing options...
dansp1 Posted January 6, 2013 Report Share Posted January 6, 2013 yes it does, and you can keep re-using it until it turns black, anything rusty just drop it in and it comes out like new, just make sure it is thoroughly degreased first (the kit comes with an excellent degreaser) follow the instructions and you wont go wrong (if you are close to barryj you can let him have a go on it when you are done, for his gpz tank) Link to comment Share on other sites More sharing options...
lorenzo Posted January 6, 2013 Report Share Posted January 6, 2013 I've done a huge thing in about june last year on using electrolysis and then a really good thing called por15, used it on the bros, whose tank was actually leaking from pin holes, and it sorted it a treat. Edit: here it is, it was on the bros thread, read down as I go through the stages. All the pictures are fucked for some reason, but rest assured, it was shit hot. Link to comment Share on other sites More sharing options...
blur1 Posted January 7, 2013 Report Share Posted January 7, 2013 To remove rust get small sharp edged pebbles. Wash them thoroughly and put about a cup full in an average sized fuel tank. Shake the tank with them in to remove the 'scale' then rinse with vinegar. Rinse again with a neutraliser like baking soda and dry thoroughly. Then use a tank liner kit. The best on the market is by 'Caswell' it is a two part epoxy and used by many after Por-15 fails because of fuel contamination. Caswell---> http://www.caswellplating.com/restoration-aids/epoxy-gas-tank-sealer.html Link to comment Share on other sites More sharing options...
lorenzo Posted January 7, 2013 Report Share Posted January 7, 2013 When have you seen anything about por15 contaminating fuel? Kreme, yes, one or two others too, but I've never once heard about por15 contaminating. Link to comment Share on other sites More sharing options...
willbloke Posted January 7, 2013 Report Share Posted January 7, 2013 http://www.flickr.co...02/8349876133/] My two stroke wasaabi earlier today Lush , fit some chambers ? Ring ding ! EDIT: Re POR15 , I think they had issues when they started adding ethanol to fuel with a lot of old tank liners melting , think POR15 is ok now ? Looking at this they do an American one for gasahol http://www.por15.com/US-STANDARD-TANK-SEALER/productinfo/TSG/ Link to comment Share on other sites More sharing options...
blur1 Posted January 7, 2013 Report Share Posted January 7, 2013 When have you seen anything about por15 contaminating fuel? Kreme, yes, one or two others too, but I've never once heard about por15 contaminating. Yep, i know two on the r1 forum that used por-15 unsuccessfully. Link to comment Share on other sites More sharing options...
dansp1 Posted January 7, 2013 Report Share Posted January 7, 2013 Thanks Willbloke, it has an expansion chamber already! howls like a banshee! and i didn't line the tank with anything , didn't need to, it looks like new and new tanks aren't lined..... Link to comment Share on other sites More sharing options...
