Okjc250 Posted January 4, 2013 Report Share Posted January 4, 2013 Just relised Brembo M/C has a diferent thread than normal banjo bolts.... Wheres best to buy a good quality banjo bolt? pro bolt? i couldnt find them on the website Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted January 4, 2013 Report Share Posted January 4, 2013 M10x1.0 Probolt, Hel, goodridge(spit). Link to comment Share on other sites More sharing options...
Toneale Posted January 4, 2013 Report Share Posted January 4, 2013 Earls is another one http://www.earls.co.uk/earls/adapters/banjobolts.html Link to comment Share on other sites More sharing options...
Okjc250 Posted January 4, 2013 Author Report Share Posted January 4, 2013 ordered a pro bolt one from ebay. Link to comment Share on other sites More sharing options...
marcaztls Posted January 5, 2013 Report Share Posted January 5, 2013 It's not always just the thread pitch (which is 't actually unique to Brembo by the way, plenty of others use that pitch too) it's also the length, 'some' Brembo components use slightly shorter banjo bolts so watch out for that before damaging a seat. Link to comment Share on other sites More sharing options...
marcaztls Posted January 5, 2013 Report Share Posted January 5, 2013 Easily sortable though. Just lathe or cut two threads off a standard length banjo bolt if you're caught out. I keep a selection of different thickness washers in to deal with pretty much all eventualities though. Not all banjo fittings are the same widths either. The sneaky bastards. Link to comment Share on other sites More sharing options...
Okjc250 Posted January 5, 2013 Author Report Share Posted January 5, 2013 ok will check this when i assemble Link to comment Share on other sites More sharing options...
