stevieweavie Posted January 4, 2013 Report Share Posted January 4, 2013 I'm trying to find out what oil to put in my 2002 hilux d4d 2.5 turbo diesel. I keep getting told different things. A garage said 10w 30 semi synthetic, eurocarparts website says 5w30 fully synth and halfords site says 15w 40 mineral. Any ideas whats best. Its done a high mileage (225000). It needs nearly 7 litres of the stuff too Link to comment Share on other sites More sharing options...
-=JK=- Posted January 4, 2013 Report Share Posted January 4, 2013 I stand to be corrected, but i'd not use a normal "mineral" oil. Think the temps are higher on turbo-diesels, and a cheap mineral would deteriorate quicker than a turbo-diesel specific oil. Other than that, go with whats within your budget. 5w30 seems to be overkill, 10w30 or a td specific 15w 40 should be just fine. my 2p's worth Link to comment Share on other sites More sharing options...
millerich Posted January 4, 2013 Report Share Posted January 4, 2013 Not the same engine, but similar...ish, I put 5w30 in my 3.0l Landcruiser, on Toyota's advice. Link to comment Share on other sites More sharing options...
VanWinkle Posted January 4, 2013 Report Share Posted January 4, 2013 A few years back when I had my own bikers website we used to use these guys for info and oil supplies http://www.opieoils.co.uk/ always good reliable info and oil supplied at a forum discount price.. its always worth asking, costs nowt. Link to comment Share on other sites More sharing options...
BudgetBoy Posted January 4, 2013 Report Share Posted January 4, 2013 Id say 5w or 10w/30 oil will be fine mate. Dont use mineral oil IMO. 5w is -25 degrees 10w is -20 degrees Wont be getting that cold lol.. The lower the 2nd number the more overall wear over the life of the engine..(thinner oil @ 100 deg C) Stick with the 30 one mate and you will be grand. Link to comment Share on other sites More sharing options...
stevieweavie Posted January 5, 2013 Author Report Share Posted January 5, 2013 T afor the replies, think i'll get some 10w 30 for a turbo diesel, not mineral tho Link to comment Share on other sites More sharing options...
potheadpixi Posted January 5, 2013 Report Share Posted January 5, 2013 A good quality C2 certified semi synth of either 5w or 10w / 30 will be fine although I would consider a 5 or 10w 40 if oil consumption is a factor on such a high mileage engine as it's slightly thicker when hot. Link to comment Share on other sites More sharing options...
