wil.co. Posted December 30, 2012 Report Share Posted December 30, 2012 I was wondering, has anyone had made up, or sourced, a 'quick release' rear wheel? well, specifically, the part that keeps the sprocket on the bike as you remove it. I know that it is sort of a locking 'jig' that slides into each other, but thats about it. What else would be involved in this, how would the sprocket stay attached? attach it to the chain adjuster? Thanks for any help... Link to comment Share on other sites More sharing options...
speedy sie Posted December 30, 2012 Report Share Posted December 30, 2012 i know to some sets for sale ill get a price...ive goe some pics,sedn my your email and send them over to you...tomorow Link to comment Share on other sites More sharing options...
gixerboy1 Posted December 30, 2012 Report Share Posted December 30, 2012 The sprocket sits on a carrier attached to the chain adjuster. The carrier has an aperture cut into the back of it that mates to a part that bolts onto the wheel in place of the sprocket and drives the sprocket carrier. I started making one earlier this year but didnt get around to finishing it. Another project to look at in the new year! Here is the sprocket side of the carrier: With the sprocket fitted: The back face where the part bolted on the wheel locates: And a few pics of the chain adjusters: The bracket with the 2 holes in it is for a mount for the brake caliper. On the other side of that is an up stand with a rail on it for the spacer of the wheel to roll into and locate easily. I dont have a pic of it together with the bearings fitted yet. I just need to make the mount that goes on the wheel and a few little parts to locate the sprocket and it would be together.Here are a few pics I based my design on: Link to comment Share on other sites More sharing options...
Superdunc Posted December 30, 2012 Report Share Posted December 30, 2012 The set up uses the standard Marchesini/Marvic/Ducati style wheels and cush drive doesn't it? The Pentagon drive has the pins that are normally on the sprocket carrier. Link to comment Share on other sites More sharing options...
gixerboy1 Posted December 31, 2012 Report Share Posted December 31, 2012 Its for an Aprilia Mille wheel and they have rubber posts so that will be incorporated into the part that bolts onto the wheel. Link to comment Share on other sites More sharing options...
Conica Posted December 31, 2012 Report Share Posted December 31, 2012 Not worried about that set-up being out of balance Gixerboy? Or is it fairly well balanced with the scalloped radius' next to the raised "wall"? Just curious innit Link to comment Share on other sites More sharing options...
wil.co. Posted December 31, 2012 Author Report Share Posted December 31, 2012 Spot on what I wanted to know... Link to comment Share on other sites More sharing options...
gixerboy1 Posted December 31, 2012 Report Share Posted December 31, 2012 When I put the bearing in it and ran it on the spindle it seemed pretty balanced, but until I put it on the knife edges to check it I am guessing. I did leave material in to be scallpoed out if it was a problem. At the end of the day it is a small diameter and weight compared with the wheel so the centrifugal force is pretty negligable. Link to comment Share on other sites More sharing options...
Cibbersicks Posted December 31, 2012 Report Share Posted December 31, 2012 Bolliger Kawasaki's solution is quite simple and elegant - if a little crude looking compared to the 'wavy' sprocket carrier. Works just fine though! Martin I love your work with what you've done above, it looks fantastic. Those chain adjusters are gorgeous! Link to comment Share on other sites More sharing options...
wil.co. Posted December 31, 2012 Author Report Share Posted December 31, 2012 Right, who is gonna make me some for my sp1, stock swing arm? Link to comment Share on other sites More sharing options...
speedy sie Posted December 31, 2012 Report Share Posted December 31, 2012 Right, who is gonna make me some for my sp1, stock swing arm? might need a widened swing arm if you use the ome wheel Link to comment Share on other sites More sharing options...
cuban pete Posted December 31, 2012 Report Share Posted December 31, 2012 Right, who is gonna make me some for my sp1, stock swing arm? a fair bit of work goes into a quick change rear . get your cheque book ready Link to comment Share on other sites More sharing options...
speedy sie Posted December 31, 2012 Report Share Posted December 31, 2012 ..this man talk sence Link to comment Share on other sites More sharing options...
srad34 Posted December 31, 2012 Report Share Posted December 31, 2012 Beautiful as it is, how much heavier than a SSSA? Link to comment Share on other sites More sharing options...
Mark/Foggy Posted January 2, 2013 Report Share Posted January 2, 2013 Answer on the weight issue is lots. Answer on a safety issue is that seemingly no matter what you do with this sort of set-up, at some point the rear wheel spindle will undo itself and start going walk about. Ask me how I know. It got something to do with the chatter that you inevitabely get, as there must be some tolerance between the 2 halfs of the drive plates. I think I may have fallen on a solution, yet to test it out. Link to comment Share on other sites More sharing options...
Marb Posted January 2, 2013 Report Share Posted January 2, 2013 How do you know? Link to comment Share on other sites More sharing options...
