Mark/Foggy Posted December 25, 2012 Report Share Posted December 25, 2012 Should be simple enough, but would like some advice/trick solutions. The Bultaco project that I'm working on is coming to an end. The wiring loom is about as simple as it gets. Generator driven by the engine, points and a single wire to the coil. Now this is fine, but I want to be able to plug chop the bike and need to be able to kill the motor on demand. So simple switch in the low tension circuit between points and coil should be the answer. Can anybody think of any pit falls, would a solenoid driven device be a better solution and is there anything 1960/70's that would look trick yet still be available, most stuff from then is pressed tin and shiiiiite. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted December 25, 2012 Author Report Share Posted December 25, 2012 Am confused by that Mike, only got one pole on the coil, fed from the points. Earth is by body contact to chassis. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted December 25, 2012 Author Report Share Posted December 25, 2012 Ok, think I got it, got any smart ideas for a 'totally reliable' switch. There's any number chinese made kill switches on the bay and obviously I've got loads of Yam switches lying about, were pit lane limiter or general toggle on/offs. the period stuff is aweful tin stuff, where do I look next? Link to comment Share on other sites More sharing options...
cagimaha Posted December 25, 2012 Report Share Posted December 25, 2012 Have a look at some of the stuff fitted to old twin shock MX bikes. The old Suzuki TM models had a subtle kill switch with a simple black rubber cover, may be some good? Link to comment Share on other sites More sharing options...
Mark/Foggy Posted December 25, 2012 Author Report Share Posted December 25, 2012 Hmmmm http://www.ebay.co.uk/itm/NEW-KILL-STOP-SWITCH-MOTOCROSS-ENDURO-TRIALS-KX-RM-KTM-/350377790319?pt=UK_Motorcycle_Parts&hash=item519424cb6f Naaaffffffffff! certainly looks right for period, suspect can do better. Link to comment Share on other sites More sharing options...
cagimaha Posted December 25, 2012 Report Share Posted December 25, 2012 The one I was thinking of looked more like: http://www.ride-engineering.com/images/products/large/MX-KS00B-AS.jpg Link to comment Share on other sites More sharing options...
Mark/Foggy Posted December 25, 2012 Author Report Share Posted December 25, 2012 Oooh that nice. Where can I get one in the UK. Can't find that in their index. Drrr now found. Likey likey. Having said that it is 50 bucks plus shipping, loving the rebuild kit though. now on edit number 2, that fits as a barclamp for the master cylinder or clutch. Can't use it unless I make up the other half of the bracket, which starts getting into the realm of a whole new project. Wonder why this is taking so long. Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted December 25, 2012 Report Share Posted December 25, 2012 That is a nice switch. Could you not fit two m6 timesert inserts into that piece, and just add a normal brake/clutch clamp half to the back of it? Link to comment Share on other sites More sharing options...
Mark/Foggy Posted December 25, 2012 Author Report Share Posted December 25, 2012 Got to say that I love it on here got a string of PM's here with someone who's offering to source that ignition switch via his brother at Uni in California. You know who you are fella, thanks. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted December 25, 2012 Author Report Share Posted December 25, 2012 That is a nice switch. Could you not fit two m6 timesert inserts into that piece, and just add a normal brake/clutch clamp half to the back of it? Lateral thinking on here as well. Yes I could, easily, in fact I know where there's a Brembo/Beringer/Yamaha/ISR/Suzuki ones without a home at the moment, It's 50 fookin dollars though. Link to comment Share on other sites More sharing options...
krazyk Posted December 25, 2012 Report Share Posted December 25, 2012 Mark on the other pic it shows with other half Link to comment Share on other sites More sharing options...
krazyk Posted December 25, 2012 Report Share Posted December 25, 2012 Link to comment Share on other sites More sharing options...
krazyk Posted December 25, 2012 Report Share Posted December 25, 2012 Looks like its on the clutch perch? Link to comment Share on other sites More sharing options...
Mark/Foggy Posted December 25, 2012 Author Report Share Posted December 25, 2012 Sadly I don't have bolt on controls. The Aermacchi's have the lever perches welded on. Link to comment Share on other sites More sharing options...
lorenzo Posted December 27, 2012 Report Share Posted December 27, 2012 Use a micro switch under the seat pad. Get off the bike and it stops. Genius. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted December 28, 2012 Author Report Share Posted December 28, 2012 Rider slides off inside of sadle, bike cuts out loading the front, countersteering and on his elbow, rider returns to the saddle while leaving the track, bike chimes back in again and high sides him off the kerb rain. Maybe not. Think again Grasshopper. Only need the switch to satisfy scrutineers and marshalls, hence why I'm looking out for something unusual. Liking this http://compare.ebay.co.uk/like/330518654606?var=lv<yp=AllFixedPriceItemTypes&var=sbar&cbt=y Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted December 28, 2012 Report Share Posted December 28, 2012 That's pretty nice. Any of these billet options could be stripped down and the metal parts powder coated satin black. That would tone them down somewhat, but they would still be good quality, and more importantly feel nice to use. Link to comment Share on other sites More sharing options...
