kja.busa Posted December 24, 2012 Report Share Posted December 24, 2012 Just needing some information please and I'm certain there are people on here who can help. Firstly the 1199 Ducati engine has aluminium cylinder liners, wet liners I believe, having never seen one I have a couple of queries. Firstly, how thick is the wall of the liner? Does it seal like a conventional type wet liner with an 'o' ring? What spec of aluminium is used to make it? And what sort of clearance is available for it to fit into the crankcase? I heard that the 1199 racebikes have reverted to cast liners after issues, this obviously changes the piston to cylinder wall clearances, but are the rings also to a different spec? Any advice or input, as ever greatly appreciated. Corrected by "Superdunc" Link to comment Share on other sites More sharing options...
porter_jamie Posted December 24, 2012 Report Share Posted December 24, 2012 what is the back story? you want to use one in something else? Link to comment Share on other sites More sharing options...
Superdunc Posted December 24, 2012 Report Share Posted December 24, 2012 Ducati liners are integral with the barrel and water jacket. Unless you mean the 1199. http://www.ebay.co.uk/itm/DUCATI-1098-1198-1098S-08-FRONT-ENGINE-CYLINDER-SLEEVE-/270704260414 Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted December 24, 2012 Report Share Posted December 24, 2012 I know very little about this, and can only speculate. These images were ruthlessly stolen from Rick Hacketts Facebook album. It's clear to see from the photos that the liner is a separate piece from the cranks cases. This is new thinking from Ducati, and has more in common with the d16. If I was to make a guess at the liner wall thickness, I would say it looks like 2-3mm, this is similar to previous production duc's. Does this help, I too am interested in your line of questioning? Link to comment Share on other sites More sharing options...
kja.busa Posted December 24, 2012 Author Report Share Posted December 24, 2012 Ducati liners are integral with the barrel and water jacket. Unless you mean the 1199. http://www.ebay.co.u...E-/270704260414 Sorry yes, the 1199. Link to comment Share on other sites More sharing options...
kja.busa Posted December 24, 2012 Author Report Share Posted December 24, 2012 what is the back story? you want to use one in something else? Yes, ideally Jaime. Basically its a possible solution to a idea that I've been pondering on. Billet barrels on a TL1000 crankcase. The limiting factor with a TL for capacity increases are the oem barrels, they simply are too weak, theres a popular 2mm overbore and then some go 4mm but the skirts on the barrels are weak. We machined an oem barrel out with the idea of fitting a steel liner but at 106mm the bore broke through into the water jacket. Ideally, using a 106mm bore and a 73mm crank we can get 1300cc, the crank has been done, the Crower titanium rods have been rebushed to run 20mm pins, 1098RS Ducati pistons are favourite, Warpspeed have offered to machine the barrels and Sam Mathewman will build the engine, just need to sort the issue of liners, hence my question. Link to comment Share on other sites More sharing options...
garage19 Posted December 24, 2012 Report Share Posted December 24, 2012 I just like the fact titanium rods are involved. Link to comment Share on other sites More sharing options...
Superdunc Posted December 24, 2012 Report Share Posted December 24, 2012 loads of 1199 engine pictures here. http://cadre-club.smugmug.com/Motorcycles/Ducati-Indianapolis-Panigale/25564145_SnDLW9#!i=2108555540&k=jkkG6zZ TTS made some billet barrels for a 1600 hayabusa engine which had seperate steel liners. That might be a better model for your conversion. Link to comment Share on other sites More sharing options...
kja.busa Posted December 24, 2012 Author Report Share Posted December 24, 2012 Steel liners might be the way to go, however again I'm not sure about the 1098RS rings running in steel liners. Link to comment Share on other sites More sharing options...
Superdunc Posted December 24, 2012 Report Share Posted December 24, 2012 I'm fairly sure the 1098rs are steel liners. who are getting to machine the liners, they should be able to advise on ring material. Link to comment Share on other sites More sharing options...
kja.busa Posted December 24, 2012 Author Report Share Posted December 24, 2012 I'm fairly sure the 1098rs are steel liners. who are getting to machine the liners, they should be able to advise on ring material. A local company has offered to make them in steel but they have no experience of bike engines, I just thought the Nikasil aluminium liners would run tighter clearances and be a good idea. Link to comment Share on other sites More sharing options...
Superdunc Posted December 24, 2012 Report Share Posted December 24, 2012 These are the kiddies when comes to liners. http://www.capricorngroup.net/en/automotive-en/laufbuchsen.html If rumors are to be believed, these people know more than a liitle about Ducati pistons and rings. http://www.omegapistons.com/ Link to comment Share on other sites More sharing options...
kja.busa Posted December 24, 2012 Author Report Share Posted December 24, 2012 Thanks Dunc, I'll research the 1098rs liners, steel looks the way to go tbh. Link to comment Share on other sites More sharing options...
Superdunc Posted December 24, 2012 Report Share Posted December 24, 2012 Sounds an awsome project, let us see how you get on. Link to comment Share on other sites More sharing options...
kja.busa Posted December 25, 2012 Author Report Share Posted December 25, 2012 Will do Link to comment Share on other sites More sharing options...
porter_jamie Posted December 25, 2012 Report Share Posted December 25, 2012 perfectbore / capricorn are the daddies re bore, and i think omega do the pistons for duc's too, as superdunc says. do you need someone to design and make the billet barrels?? Link to comment Share on other sites More sharing options...
garage19 Posted December 25, 2012 Report Share Posted December 25, 2012 You know of anyone Jamie? Link to comment Share on other sites More sharing options...
porter_jamie Posted December 25, 2012 Report Share Posted December 25, 2012 er, maybe, let me think.. Link to comment Share on other sites More sharing options...
tootall Posted December 25, 2012 Report Share Posted December 25, 2012 A 1300 TL? What could possibly go wrong? love it Link to comment Share on other sites More sharing options...
