addiction269 Posted February 1, 2009 Report Share Posted February 1, 2009 as above the throttle will not return after opening, just rebuilding and could do with answers cheers Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted February 1, 2009 Report Share Posted February 1, 2009 Ello mate,first you need to establish if its the cable or at the grip end or carb end.Usual faults are---1.dirt or old gunk in the throttle tube(the bit the grip sits on)cleanup with brake cleaner/degreaser and give it a light oiling.2.cable hasn't got a nice freerun-i.e. its kinked-had it apart?3.cable needs oiling?4.cable slack misadjusted--back it right off and start again.try pulling the cable by hand with it disconnected-see if it returns good then. good luck! Sorry mate--i see you HAVE had it apart-it's propably binding as youve misrouted it then Link to comment Share on other sites More sharing options...
addiction269 Posted February 1, 2009 Author Report Share Posted February 1, 2009 thanks for the advice ill keep on at it - when it stops snowing anyways! Link to comment Share on other sites More sharing options...
