wazrs257 Posted December 7, 2012 Report Share Posted December 7, 2012 Can anybody point me in the direction of somewhere I can get a rubber/silicone t-piece radiator hose. It needs to be 19mm i/d in all 3 bores. The only ones I can find are for BOVs and have large main bores. I've tried using a plastic T-piece but there isn't enough room for it and the rubber joining hoses, IYSWIM. HELP!!! Link to comment Share on other sites More sharing options...
porter_jamie Posted December 7, 2012 Report Share Posted December 7, 2012 samco? Link to comment Share on other sites More sharing options...
marcaztls Posted December 7, 2012 Report Share Posted December 7, 2012 Hmmmm, I've used autosiliconehoses.com for a lot of stuff in the past, but just checking and they only go down to 25mm ID on their tee's. PM member kanerdog1x1 on here though as I've a sneaky suspicion he may just be able to point you at somewhere Link to comment Share on other sites More sharing options...
porter_jamie Posted December 7, 2012 Report Share Posted December 7, 2012 http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_categoryId_255228_productId_170668_langId_-1?cm_mmc=Shopping-_-Google%20Product%20Search-_-Car%20Maintenance%2FCar%20Components%2FNuts,%20Bolts,%20Screws%20%26%20Fixings-_-Mafco%20Hose%20Connector%203%2F4%22%20T-Piece&source=shopping might work? Link to comment Share on other sites More sharing options...
wazrs257 Posted December 7, 2012 Author Report Share Posted December 7, 2012 I've tried Samco and all the other bling hose manufacturers, but they seem to be only in large sizes. Is there a database of OE hoses I could trawl through? Will PM Kanerdog.right now! Link to comment Share on other sites More sharing options...
wazrs257 Posted December 7, 2012 Author Report Share Posted December 7, 2012 http://www.halfords....source=shopping might work? Already tried these. They would do the job if I had more space, but needing a rubber joining hose inbetween these and the rad means there isn't enough space. Plus you end up with loads of hose clips, which looks really messy. Link to comment Share on other sites More sharing options...
porter_jamie Posted December 7, 2012 Report Share Posted December 7, 2012 http://compare.ebay.co.uk/like/150951417899?var=lv<yp=AllFixedPriceItemTypes&var=sbar&cbt=y ?? Link to comment Share on other sites More sharing options...
El Gringo Posted December 7, 2012 Report Share Posted December 7, 2012 http://www.minispares.com/product/classic/PCH10532.aspx Dunno what size it is though Link to comment Share on other sites More sharing options...
wazrs257 Posted December 7, 2012 Author Report Share Posted December 7, 2012 http://www.minispare...c/PCH10532.aspx Dunno what size it is though That looks like it may do the job Chris, cheers. I'll give them a ring and find out the bore size. Link to comment Share on other sites More sharing options...
